mike Posted December 10, 2020 Share Posted December 10, 2020 I hit a deer a while back and have finally started getting parts from Yamaha to put the bike back together. I didn't go down but the Tupperware was trashed on both sides up front, the fender was destroyed, the radiator was trashed and the front headlight/screen mounting frame was bent to the left. This is a great time to make a couple of changes and one will be the installation of a set of LED turn signals. Do both the front and rear lights require the same adapters to mount the lights to the body work? I have ordered a kit from TST for the front but their package for the rear is geared to their fender eliminator kit. I plan on keeping the rear license plate and taillight assembly an just replace the signal lights and want to make sure I have the proper parts to make the swap. Link to comment Share on other sites More sharing options...
Coop Posted December 10, 2020 Share Posted December 10, 2020 The oem lights both mount the same way, so yes. Those little clamp rings are a pita, but you can work them off with a pick. 1 Link to comment Share on other sites More sharing options...
