bootsandboots Posted June 3, 2021 Share Posted June 3, 2021 For those that have (or have had) an earlier FJ09 with a Corbin seat… do you have a rear rack you recommend that fits with the seat? I initially went with a rear rack from T-Rex racing but after having to exchange twice due to the racks not remotely lining up with install points I ultimately returned and gave up for a while. When I had my second rack from them (that still wouldn’t fit correctly) I had just got my Corbin seat in the mail and learned that even if the rack would install correctly that the Corbin seat wouldn’t work with it. Besides my issues T-Rex’s customer service was top tier and allowed me to return no questions asked. I digress… I’m looking for a rack similar in style that has a flat top for my Kriega US30 dry bag that fits with the Corbin seat. Any insight would be greatly appreciated. Link to comment Share on other sites More sharing options...
Supporting Member Heli ATP Posted November 11, 2021 Supporting Member Share Posted November 11, 2021 I'm looking for a rear rack for my 2017 FJ-09 that will work with the Yamaha stock side cases and Corbin seat. Got the Shad rear rack mount but it requires removal of Yamaha side case brackets. An ebay special would work if I could determine which rear rack is compatible with the side case mounts. (Anyone want to trade my Shad rear rack mount for a Yamaha one). The FJ-09 REAR RACK/ TOP CASE MOUNT is no longer available. FJ-09 Stock rear rack Link to comment Share on other sites More sharing options...
OZVFR Posted November 11, 2021 Share Posted November 11, 2021 I have the same Shad bracket and have no problem with the stock side case brackets, I use the side cases all the time. 1 Link to comment Share on other sites More sharing options...
OZVFR Posted November 11, 2021 Share Posted November 11, 2021 1 Link to comment Share on other sites More sharing options...
Supporting Member Heli ATP Posted November 11, 2021 Supporting Member Share Posted November 11, 2021 Thanks for the pics. I guess I didn't try hard enough. What year bike do you have? Link to comment Share on other sites More sharing options...
OZVFR Posted November 12, 2021 Share Posted November 12, 2021 (edited) 2015. All I needed was some gal packing washers and longer high tensile bolts. Cases go on no problem. Edited November 12, 2021 by OZVFR 1 Link to comment Share on other sites More sharing options...
Supporting Member Heli ATP Posted November 18, 2021 Supporting Member Share Posted November 18, 2021 On 11/11/2021 at 4:31 PM, OZVFR said: I have the same Shad bracket and have no problem with the stock side case brackets, I use the side cases all the time. OK now I see how you made this work, no hand hold rails. It's hard to find a rack that will work with the hand hold rails, the stock pannier holders and a Corbin seat. Link to comment Share on other sites More sharing options...
Mako Posted November 18, 2021 Share Posted November 18, 2021 I have a 2015 FJ09. The Shad rack mount works well with a Corbin seat. Link to comment Share on other sites More sharing options...
Supporting Member Heli ATP Posted November 19, 2021 Supporting Member Share Posted November 19, 2021 10 hours ago, Mako said: I have a 2015 FJ09. The Shad rack mount works well with a Corbin seat. Yes it does, but your stock side case holders had to be removed. Or you could have left them on and remove the hand hold rails instead. I want it all 🙂 Link to comment Share on other sites More sharing options...
OZVFR Posted November 19, 2021 Share Posted November 19, 2021 (edited) I can’t see why you couldn’t leave the handrails on. It shouldn’t interfere with the side case brackets. Here is is on a camping trip last weekend: Edited November 19, 2021 by OZVFR Link to comment Share on other sites More sharing options...
