nhchris Posted June 30, 2021 Share Posted June 30, 2021 Can someone tell me where the temp sensor is located in the cooling system? It seems very responsive to air flow through the radiator, either by fans or bike movement. Which makes me wonder if it accurately indicates engine temp which can't rise or fall that fast. Also, any of you speed-racers running an oil temp gauge on the C3? 1968 Triumph Bonneville 650 1971 Norton Commando Roadster 2002 Harley 1200 Sportster 2003 Honda ST 1300 2016 FJ 09 Link to comment Share on other sites More sharing options...
tedski Posted June 30, 2021 Share Posted June 30, 2021 It's a coolant temperature sensor, not an engine temperature sensor. The coolant does change temperature that fast, of course. As to where it is, it's in the back of the head on the right hand side of the bike. See: and 1 Link to comment Share on other sites More sharing options...
