peteinpa Posted October 27, 2021 Share Posted October 27, 2021 Finally got around to using the bottle of Drislide I got what, 3 months ago. I tried dribbling 3 different lubes down my throttle cables in the past...Nothing gets down to the end. Throttle hard to turn. You can't use the cable lubers, can't connect to throttle cables. Shook bottle of Drislide, installed needle, and started squirting into end of cables with throttle disassembled at tube on handlebar. This stuff is thin, flows better than water! before I knew it I had a mess under my bike from it coming out dripping at the TB end. Totally found the bad spot in my cables and now the throttle turns SUPER easy! Best lube for cables I've ever found! Saved me $35 for a new cable I was going to buy and change out this winter. 👍🙂 THANKS Betoney!! 2 1 Link to comment Share on other sites More sharing options...
