Rosscofat Posted March 7, 2022 Share Posted March 7, 2022 (edited) I installed Denali S4 with DialDim on my tracer 900 GT and it went smooth and easy. What a great system. There are all the photos. I will run a second circuit for extra turn signals etc later on. Photos of the S4 installed. Edited March 7, 2022 by Rosscofat Added link 2 Link to comment Share on other sites More sharing options...
flyfifer Posted March 8, 2022 Share Posted March 8, 2022 Why ? if I might ask ! Link to comment Share on other sites More sharing options...
flyfifer Posted March 8, 2022 Share Posted March 8, 2022 (edited) Ok. "Denali S4 features two flood optics and two spot optics to create a super wide close-range flood and a piercing spot beam in one housing. The S4 DataDim™ Technology enables the lights to be upgraded in seconds to dual intensity. By connecting a plug-n-play DataDim™ Controller they automatically switch the lights between half and full intensity with your vehicle's original high beam switch." I took the above from a Denali info. Without the DataDim controller can the S4 lights be switched between "half and full intensity" with the switch that is supplied ?? Are the flood and spot light, in each housing, switched separately, or do they come on together ? Have you got a pic of the mounting bracket fixing taken from the side ? Are brackets supplied in the kit ? Edited March 8, 2022 by flyfifer Link to comment Share on other sites More sharing options...
Rosscofat Posted March 8, 2022 Author Share Posted March 8, 2022 (edited) I used the Givi LS2139 bracket. Both flood and spot bulbs are on at the same.time to give you maximum coverage. I wanted to have more coverage at night riding in the backroads. I wanted the DialDim accessory so when I use my turn signals the flood on whatever side I'm turning on turns off so it can still be seen along with I can adjust the intensity much more with the Dial. Edited March 8, 2022 by Rosscofat Updated Link to comment Share on other sites More sharing options...
flyfifer Posted March 8, 2022 Share Posted March 8, 2022 (edited) Rosscofat, I appreciate your extra info. Can I clarify, -- The two pod kit does not have an on/off switch. Correct/Wrong ? Without the DataDim device do the pods light on full intensity when power connected ? I did not know about the,DataDim , Denali pod off with turn signal on function. Sounds a good idea. Crystal clear ref, spot/ flood light on together, design. I made a givi2139 clone to mount my cheap ex China lights, so that's clear as well. Edit. I found this Denali switch info. Obviously, doesn't link to the turn signals. "The DENALI HI-LOW-OFF Switch replaces the standard ON-OFF switch. The switch enables independent dimming of the lights, separate from the vehicle's OEM lighting system. Option for those who want full independent control of their auxiliary lights. " Edited March 8, 2022 by flyfifer Link to comment Share on other sites More sharing options...
Rosscofat Posted March 8, 2022 Author Share Posted March 8, 2022 The S4 kit just comes with a on off. You add the datadim kit to get the Hi-Lo off switch. Or you get the DialDim to have off and it cdn increase by 15% each notch on the dial. The DialDim has signal wires that you tap into your turn signals/horn/HighBeam for other features. You can wire so when you honk your fog lights can strobe at the same time, flip high beam it will go to full intensity etc. it also is ready to plug in another set of lights and also control them off the same dial. Link to comment Share on other sites More sharing options...
flyfifer Posted March 8, 2022 Share Posted March 8, 2022 (edited) Bit between my teeth now. I found this ref Yamaha T7 "problem is that the high beam wire doesn’t provide 12 v when on. Since the T7 has LED headlights the available headlight wire doesn’t provide what’s needed by the Datadim module. The only option I have been able to find is the three position switch Denali offer. " Also found this which obviously helps understand how the DataDim works. Do the controller and switch have handlebar mounting clamps supplied ? What do the lights do when the horn blows -- go to full intensity ?? Edited March 8, 2022 by flyfifer 1 Link to comment Share on other sites More sharing options...
flyfifer Posted March 8, 2022 Share Posted March 8, 2022 (edited) Rosscofat, You were obviously typing when I was. Your comments complete the story, thanks. I had vaguely heard something about the Strobe effect but didn't know what switched it. That's now Crystal clear. ! Thanks. Edited March 8, 2022 by flyfifer Link to comment Share on other sites More sharing options...
flyfifer Posted March 8, 2022 Share Posted March 8, 2022 (edited) So a "complete" kit is a Pair of S4pods £250 great british pounds with a Data Dim rotary switch kit and a Three position switch for £80 gbp OR a Dial Dim controller Kit. £200 great British pounds. (and a choice of mounting bracket). Edited March 8, 2022 by flyfifer Link to comment Share on other sites More sharing options...
Rosscofat Posted March 8, 2022 Author Share Posted March 8, 2022 Yes. I was going to go with the high low but I wanted more control over the lights during day and night. so I run them around 15% during the day and around 50% at night in city traffic. Anytime I am not around any other cars I go 100% the 2nd Circuit (Green circuit) I will run will be Front fender lights that will Flash with the turn signals compared to the Blue Circuit that turns off depending on the turn signal https://denalielectronics.com/products/drl-visibility-pod-white-or-amber Link to comment Share on other sites More sharing options...
Rosscofat Posted March 8, 2022 Author Share Posted March 8, 2022 (edited) 11 minutes ago, flyfifer said: So a "complete" kit is a Pair of S4pods, a Data Dim rotary switch kit and a Dial Dim controller Kit. (and a choice of mounting bracket). No all you would need is the Dialdim unit as it does everyone the Datadim does. I bought this exact kit With the 21-29mm crashbars https://www.abikething.com/product/denali-dial-dim-bundle/ Here is a video also Edited March 8, 2022 by Rosscofat updated info 1 Link to comment Share on other sites More sharing options...
Supporting Member piotrek Posted March 8, 2022 Supporting Member Share Posted March 8, 2022 Very cool system...albeit rather expensive. 1 Link to comment Share on other sites More sharing options...
Rosscofat Posted March 8, 2022 Author Share Posted March 8, 2022 1 hour ago, piotrek said: Very cool system...albeit rather expensive. Yes it was.. around $750 Canadian total shipped the quantity is worth the price. Link to comment Share on other sites More sharing options...
PHT70 Posted May 7, 2023 Share Posted May 7, 2023 Hi I'm installing a dial dim with lights to my 9GT the problem is I have no idea of where to take the hi beam sensor feed from. Where did you run yours from? Cheers. Link to comment Share on other sites More sharing options...
Ejay Posted December 13, 2023 Share Posted December 13, 2023 Hi. I’ve just installed the dialdim and the s4 too. As for the hi beam feed it’s a little complicated as it’s not a 12V positive source. You’ll have to use a relay to convert it from a negative to a positive feed. Link to comment Share on other sites More sharing options...
