marcuso Posted May 26, 2023 Share Posted May 26, 2023 Like the title says..... My battery was giving me some hints to maybe replace. I did.... I tried to start up and it cranks and flutters... Vid to follow. Any insight?? Thanks in advance. Mark Link to comment Share on other sites More sharing options...
Premium Member 1moreroad Posted May 27, 2023 Premium Member Share Posted May 27, 2023 Was the new battery fully charged? What's the voltage of the battery before/after connecting it to the bike? Did it have the water added? I thought even some AGM batteries are shipped inactive and need to be activated before use. 1 Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted May 27, 2023 Premium Member Share Posted May 27, 2023 AGM usually come with an electrolyte pack and then need to be carefully at 1.25 amps charged to 13 volts. Check at rest and under load battery voltages. Maybe run an amperage draw test. Did you clean the connections and treat with dielectric grease. 2 Link to comment Share on other sites More sharing options...
