kifakw Posted July 26, 2015 Share Posted July 26, 2015 with regards to the issue that many others have commented about the steering wobbling, many others have adjusted their suspension to better suit their weight and seems to help in the situation. let us share our suspension information below to see what is the recommended setup for street riding while alleviating/resolving the wobbling issue. My Setup front preload: 6 lines (towards soft) (standard 16 mm; 4.0 mm ~ 19.0 mm; 4.0mm being hard ~ 19.0mm being soft) front rebound: 9 clicks (towards soft) (standard 7 clicks; 1 ~ 11 clicks; 1 being hard ~ 11 being soft) rear preload: 3 (towards soft) (standard 4; 1 ~ 7; 1 being soft ~ 7 being hard) rear rebound: factory stock weight of rider: 152 lb / 69kg single/2-up: solo tyre psi: 34 / 36 (factory recommend 36 / 42) tyre make / model: factory stock Your Setup front preload: front rebound: rear preload: rear rebound: weight of rider: single/2-up: tyre psi: tyre make: [/url] [/url] Link to comment Share on other sites More sharing options...
kifakw Posted July 29, 2015 Author Share Posted July 29, 2015 Just some information to take note of while setting your sag FJ09 / MT09-Tracer Front Travel Suspenion: 137 * 30% = 41.1mm FJ09 / MT09-Tracer Rear Travel Suspenion: 130 * 30% = 39mm My Setup front preload: 1 line (towards hard) front rebound: 4 clicks (towards hard) Static Sag: 152 - 111 = 41mm rear preload: 3 (towards soft) rear rebound: factory stock Static Sag: 500 - 460 = 40mm weight of rider: 152 lb / 69kg single/2-up: solo tyre psi: 34 / 36 (factory recommend 36 / 42) tyre make / model: factory stock Read more: http://fj-09.org/thread/1994/tracer-steering-wobbling-suspension-settings#ixzz3hHDsO4N2 Link to comment Share on other sites More sharing options...
koth442 Posted August 19, 2017 Share Posted August 19, 2017 I'm bringing this back from the dead as I was setting my sag today and this thread really helped. '15 FJ09 Link to comment Share on other sites More sharing options...
