frosky Posted October 24, 2015 Share Posted October 24, 2015 I ride an FZ.. have thought of swapping in an fj rear shock for the upgraded damping. The suspension gurus say a stiffer spring on the fz stock shock will actually make the pogo effect worse. I go about 220 without gear and would likely benefit from stiffer spring. Anyone go to a stiffer spring on the stock fj shock? Link to comment Share on other sites More sharing options...
toast Posted October 24, 2015 Share Posted October 24, 2015 IMO, the stock shock doesn't need a spring. I weigh 240lbs with gear and with panniers I only needed one click higher on the preload from default to get 33% race sag. Its a bit harsh on high speed compression though just like the front. Link to comment Share on other sites More sharing options...
frosky Posted October 24, 2015 Author Share Posted October 24, 2015 IMO, the stock shock doesn't need a spring. I weigh 240lbs with gear and with panniers I only needed one click higher on the preload from default to get 33% race sag. Its a bit harsh on high speed compression though just like the front. Noticed your thread on the parts section and on the fz09 forum.. take it you went through with the swap? Link to comment Share on other sites More sharing options...
frosky Posted October 24, 2015 Author Share Posted October 24, 2015 IMO, the stock shock doesn't need a spring. I weigh 240lbs with gear and with panniers I only needed one click higher on the preload from default to get 33% race sag. Its a bit harsh on high speed compression though just like the front. Noticed your thread on the parts section and on the fz09 forum.. take it you went through with the swap? Nm... just double checked the thread I referenced. Different person altogether. Anyway.. stock spring is good for you on the fj that weighs 50lb more than fz? Link to comment Share on other sites More sharing options...
norwest Posted October 28, 2015 Share Posted October 28, 2015 IMO, the stock shock doesn't need a spring. I weigh 240lbs with gear and with panniers I only needed one click higher on the preload from default to get 33% race sag. Its a bit harsh on high speed compression though just like the front. Are you referring to the FZ-09 shock or the FJ-09 shock that has the correct spring for a 240# rider? Terry Link to comment Share on other sites More sharing options...
toast Posted October 28, 2015 Share Posted October 28, 2015 The FJ09 shock. Link to comment Share on other sites More sharing options...
