ericm Posted December 15, 2015 Share Posted December 15, 2015 I installed T-Rex case savers the other day, and now the alternator side is leaking oil slightly. I was surprised there was oil behind that cover. I'm used to two strokes where there's no oil there. when I installed them I removed the bottom stock bolts and installed the case saver and the new longer bolts. The other side's dry. Anything I should have done or should do when I remove the case saver from that side and put the stock bolts back in? Link to comment Share on other sites More sharing options...
yami Posted December 16, 2015 Share Posted December 16, 2015 I always check the lengths of the bolts if I pick more the one out. If the bolts are longer then whats expected in the hole and you screw them in to hard you will trash the threading. Your T-Rex bolts is maybe on the longer side and wont press the OEM covers enough. Make sure they are not to long. Link to comment Share on other sites More sharing options...
fullclip Posted January 29, 2016 Share Posted January 29, 2016 I have had bad things happen with t-Rex stuff and I will never buy a thing from them anymore! Terrible customer service and they make complete junk in my mind!! Link to comment Share on other sites More sharing options...
Premium Member fanowater Posted January 30, 2016 Premium Member Share Posted January 30, 2016 That's unnerving. I just received a set of case savers today. Will have to be extra careful on the install. Will report back. Cheers 2015 FJ-09 2006 Triumph Daytona 675 Link to comment Share on other sites More sharing options...
Premium Member fanowater Posted January 30, 2016 Premium Member Share Posted January 30, 2016 I went thru all the pieces last night. One of the lower covers doesn't have a completely straight standoff and one isn't flush with the others, but other than that the pieces seem well made. As long as the bolt lengths are correct, a washer should fill the gap and all will be fine. I will be installing them this afternoon, so we will see. Cheers p.s. Thanks for the info on the length of hardware you used. Might be able to get those lengths locally if need be. 2015 FJ-09 2006 Triumph Daytona 675 Link to comment Share on other sites More sharing options...
fattraxx Posted January 30, 2016 Share Posted January 30, 2016 I installed a set of these a couple of months ago. I've had no leaks or weaps. Install was straight forward and the hardware was correct. Just wish I had these on before the bike got knocked over in a parking lot. Link to comment Share on other sites More sharing options...
Premium Member fanowater Posted January 30, 2016 Premium Member Share Posted January 30, 2016 I installed a set of these a couple of months ago. I've had no leaks or weaps. Install was straight forward and the hardware was correct. Just wish I had these on before the bike got knocked over in a parking lot. So I installed mine today as well. So far no leaks or weaps either. But, the real test will be after a ride. Hopefully we will go a day without rain and the dirt road I live on will dry enough for me to escape for awhile. For the price they seem like a really good deal.Cheers 2015 FJ-09 2006 Triumph Daytona 675 Link to comment Share on other sites More sharing options...
Premium Member estell Posted January 31, 2016 Premium Member Share Posted January 31, 2016 I've ridden 4500 miles with my T-rex kit. No leaks at all. I consider it a good value. 2015 red FJ-09: Cal Sci screen, Sargent seat, ECU flash, slider combo, cruise, Rizoma bars, Matts forks, JRi shock, slipper clutch Link to comment Share on other sites More sharing options...
slownsteady Posted November 20, 2016 Share Posted November 20, 2016 Any update? Get this fixed? I recently installed this kit: T-Rex Racing Slider Kit Some oil leaked from the engine side covers during the installation. You have to remove/replace the lower bolts for the side cases which allows a small amount of oil to leak. I haven't had a leak since installation. If you're having an oil leak following installation of the slider kit, the bolts for the sliders are either too loose or the incorrect length. Link to comment Share on other sites More sharing options...
kenji Posted April 18, 2017 Share Posted April 18, 2017 I had a couple drops of oil when the mounting screws were out, but after installing the case savers, no issues. Link to comment Share on other sites More sharing options...
