Premium Member rustyshackles Posted May 30, 2016 Premium Member Share Posted May 30, 2016 Is anyone running these? A forum search came up empty. IBA Member #59800 3 Nations Brewing Mug Club #100 Link to comment Share on other sites More sharing options...
zachd Posted May 30, 2016 Share Posted May 30, 2016 I haven't seen anyone with them. There are so many cheaper options out there that are equally as good. Link to comment Share on other sites More sharing options...
wpgfj09 Posted June 9, 2016 Share Posted June 9, 2016 I've taken delivery of mine. Just waiting on mounts to mount them to my crash bars and connectors to tie into accessory power supply. I'll post pics once done. Need to get my hands on a shop manual as well. Link to comment Share on other sites More sharing options...
ed Posted June 12, 2016 Share Posted June 12, 2016 I have them and they are great. The only issue I'm having is that I wanted them to come on when I use my stock brights switch. I can't find the right wire to tap into to make this happen. The shop manual diagram isn't much help. Right now I have the Denali's tapped into a switched power source which mean I control them with the supplied Denali toggle switch, not ideal. The Denali's do come with a nice easy to install harness. Link to comment Share on other sites More sharing options...
wpgfj09 Posted June 15, 2016 Share Posted June 15, 2016 http://fj-09.org/thread/3794/denali-dm-install Link to comment Share on other sites More sharing options...
Premium Member rustyshackles Posted June 22, 2016 Author Premium Member Share Posted June 22, 2016 I have them installed. They're bright, inconspicuous, and fit the aesthetic of the bike IMO. Not inexpensive but quality looks great. IBA Member #59800 3 Nations Brewing Mug Club #100 Link to comment Share on other sites More sharing options...
Premium Member washufiddyfo Posted June 22, 2016 Premium Member Share Posted June 22, 2016 I have them and they are great. The only issue I'm having is that I wanted them to come on when I use my stock brights switch. I can't find the right wire to tap into to make this happen. The shop manual diagram isn't much help. Right now I have the Denali's tapped into a switched power source which mean I control them with the supplied Denali toggle switch, not ideal. The Denali's do come with a nice easy to install harness.ed, check out this other thread for your goal of using the standard high beam switch - it's a negatively switched setup, so a bit confusing at first http://fj-09.org/thread/2263/high-beam-wire Link to comment Share on other sites More sharing options...
