ripsaw Posted August 27, 2016 Share Posted August 27, 2016 I know this has been discussed before. I am confused. Where do I tap in to the high beam hot-and what color of wire? Also, where do I tap into the low beam and what color of wire? I had to order the Relay from Clearwater. They were wired in on my Vstrom with no relay. Appreciate any help. Link to comment Share on other sites More sharing options...
JJM Posted August 27, 2016 Share Posted August 27, 2016 The high beam "trigger" wire is actually a ground wire. It's a yellow w/ black stripe if I remember correctly. You can find it in the wiring harness that comes from the bars and goes down the brake side of the triple tree. So tap it to the ground post of your relay. Don't use it to ground the lights. Link to comment Share on other sites More sharing options...
pcarnut Posted October 18, 2016 Share Posted October 18, 2016 The high beam "trigger" wire is actually a ground wire. It's a yellow w/ black stripe if I remember correctly. You can find it in the wiring harness that comes from the bars and goes down the brake side of the triple tree. So tap it to the ground post of your relay. Don't use it to ground the lights. Getting ready to move my Darlas from my Tiger 1050 to the FJ. Ripsaw, did this work? SoCal 2015 FJ-09 Red of course Link to comment Share on other sites More sharing options...
Premium Member washufiddyfo Posted October 19, 2016 Premium Member Share Posted October 19, 2016 Details on this thread http://fj-09.org/thread/2263/high-beam-wire?page=2 Link to comment Share on other sites More sharing options...
