dunk43 Posted September 10, 2017 Share Posted September 10, 2017 Did my break in today with 557 on the odometer also did the oil pan mode and used the Mazda drain plug with yamaha crush washer. Cleaned and waxed/oiled the chain.Before I put the oil in I took 7 oz out of one of the 32 oz bottles and then put the rest along with the other 2 full bottles in and the oil line was perfect center in the check window. Link to comment Share on other sites More sharing options...
dunk43 Posted September 11, 2017 Author Share Posted September 11, 2017 Guess this should be in the what I did to my FJ09 today, sorry. Link to comment Share on other sites More sharing options...
Premium Member DavidS Posted September 11, 2017 Premium Member Share Posted September 11, 2017 Congrats on the first oil change milestone, and don't worry about where you posted. As you participate more, you will see all kinds of things, but no one is here to judge! Link to comment Share on other sites More sharing options...
carey Posted September 11, 2017 Share Posted September 11, 2017 Welcome to FJ09 ownership. I have a Mazda oil plug sitting on my work bench. I ended up using a drain plug from a R1 that had a magnet. Link to comment Share on other sites More sharing options...
Premium Member DavidS Posted September 11, 2017 Premium Member Share Posted September 11, 2017 Did my break in today with 557 on the odometer also did the oil pan mode and used the Mazda drain plug with yamaha crush washer. Cleaned and waxed/oiled the chain.Before I put the oil in I took 7 oz out of one of the 32 oz bottles and then put the rest along with the other 2 full bottles in and the oil line was perfect center in the check window.I can't remember if the Mazda plug is Torx, like the VW, but if it is, don't forget to put the torx tool in the repair bag you carry when you ride. Link to comment Share on other sites More sharing options...
dunk43 Posted September 11, 2017 Author Share Posted September 11, 2017 It a hex key. I used a yamaha crush washer torqed to 25 NM. Link to comment Share on other sites More sharing options...
