jlomb436 Posted November 12, 2017 Share Posted November 12, 2017 Hey guys, About a year ago I purchased Givi Trekker cases and I never put them on due to fitment issues with the fender eliminator I purchased on here. Essentially, the brackets don't mount because on my fender eliminator, the turn signals are too wide and tall. I've looked at a couple of other ones on Revzilla but I'm not sure if I would run into the same problem. I really dislike the OEM license plate holder, but could be my only option. Does anyone know of one that works with the Givi cases? Some of the options I was considering below. Or maybe some much smaller turn signals? https://www.revzilla.com/motorcycle/yoshimura-fender-eliminator-kit-yamaha-fz-09-fj-09 https://www.revzilla.com/motorcycle/puig-fender-eliminator-kit-yamaha-fz-09-fj-09 Thank you! Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted November 12, 2017 Supporting Member Share Posted November 12, 2017 Or maybe some much smaller turn signals? I use the X-Arc turn signals from High Tech Speed. They are small but RIDICULOUSLY bright. Don't bother with the cheap LED signals from Ebay, they aren't even in the same league when compared side by side with these. ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
nickest85 Posted November 12, 2017 Share Posted November 12, 2017 I have the giving trekker cases and fender elimator. But I put the integrated tail light with turn signals built in. You could probably get the flush mount turn signals that they make for the front and adapt them to the rear. I have thought about doing that. Link to comment Share on other sites More sharing options...
jlomb436 Posted November 13, 2017 Author Share Posted November 13, 2017 Woa, thanks guys! That's funny. I thought about buying the tail light with them built in. I thought about this awhile ago not for this reason, but for the safety of it flashing when braking. This might be the best option, but I'll take a look at those lights as well. Link to comment Share on other sites More sharing options...
