hoopdie Posted April 24, 2018 Share Posted April 24, 2018 Well the weather finally broke and I was able to ride about 15 miles on the expressway. I noticed at speeds 75mph and up to 85mph the front end had a sensation that it was light, wobbly almost. Wind speed was no more then 10 mph at tops. I’m guessing suspension, but am looking for any insight. I’m a husky petite 230lbs, probably add no more then 10lbs for gear. Thanks for looking! Link to comment Share on other sites More sharing options...
greyghost38405 Posted April 24, 2018 Share Posted April 24, 2018 I noticed that same thing when I first rode my bike home from the dealer. Once I cranked in the proper preload for my weight, front and rear, this issue went away completely. Hope this helps. Link to comment Share on other sites More sharing options...
Premium Member woop Posted April 24, 2018 Premium Member Share Posted April 24, 2018 Speed wobbles on this bike have been commented on before. Seems to most often occur at high 100+ speed when a shift of weight to the rear causes the front end to get light and susceptible to oscillation. Seems like the lighter you are the more likely you can adjust the stock suspension to compensate. I am “petite” like you and ended up upgrading the suspension on my ‘15. That worked for me. Good luck to you. Link to comment Share on other sites More sharing options...
koth442 Posted April 24, 2018 Share Posted April 24, 2018 How's your tire pressure? '15 FJ09 Link to comment Share on other sites More sharing options...
pattonme Posted April 24, 2018 Share Posted April 24, 2018 I’m a husky petite 230lbs, probably add no more then 10lbs for gear. Preload alone won't really solve the problem. You need both fork and shock springs. Link to comment Share on other sites More sharing options...
hoopdie Posted April 24, 2018 Author Share Posted April 24, 2018 How's your tire pressure? 36F 42R based on manual. Check it every time I go out. Link to comment Share on other sites More sharing options...
hoopdie Posted April 24, 2018 Author Share Posted April 24, 2018 I’m a husky petite 230lbs, probably add no more then 10lbs for gear. Preload alone won't really solve the problem. You need both fork and shock springs. Any recommendations are appreciated. I know there’s a butt load of em out there I just wouldn’t have a clue for my weight. Link to comment Share on other sites More sharing options...
koth442 Posted April 24, 2018 Share Posted April 24, 2018 pattonme (Matt) is "the guy" for the FJ. He'll get you sorted. '15 FJ09 Link to comment Share on other sites More sharing options...
pattonme Posted April 24, 2018 Share Posted April 24, 2018 230+15(gear)=245lb leads to 0.95kg/mm fork, 110N/mm (625lb/in) shock But the OE shock spring is a custom length so if you insist on trying to use the OE shock (the rebound circuit can't cope with the beefier spring) you'll need a spacer. You really should get a $500-class shock at minimum (K-Tech Razor-Lite, Ohlins 335) and the fork springs. Link to comment Share on other sites More sharing options...
hoopdie Posted April 24, 2018 Author Share Posted April 24, 2018 230+15(gear)=245lb leads to 0.95kg/mm fork, 110N/mm (625lb/in) shock But the OE shock spring is a custom length so if you insist on trying to use the OE shock (the rebound circuit can't cope with the beefier spring) you'll need a spacer. You really should get a $500-class shock at minimum (K-Tech Razor-Lite, Ohlins 335) and the fork springs. Thanks for your time, I appreciate the help! Link to comment Share on other sites More sharing options...
