krupted Posted June 20, 2018 Share Posted June 20, 2018 Leaving work yesterday I keyed on the bike, put on my helmet, and then pressed the starter button and the engine cranked and cranked, maybe 8-10 times, but never actually fired. I stopped cranking and noticed a code on the display "091". I turned off the key and let it sit for 30 secs, turned on the key and let it do its fancy "boot up" display thing, and then pressed the starter button and it started like normal. The issue didn't happen this AM. I googled it, but I can't find anything for fault/error code 091. Does anyone know what it means? Mark Current Ride - 2003 Kawasaki KLR650 Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted June 20, 2018 Supporting Member Share Posted June 20, 2018 I dont even see 091 on the list 12 Crankshaft Position sensor 13, 14, 20, 25, 26 Intake air pressure sensor 15 Throttle Position sensor 19 Kickstand Switch 21 Coolant temperature switch 22 Intake air temperature sensor 24 Oxygen sensor 30 & 41 Lean angle sensor 33, 34, and 35 Ignition coil 1, 2, and 3 respectively 39 Fuel Injector 42 Rear wheel speed sensor, clutch switch, or neutral switch 43 Fuel system voltage low 46 Charging voltage abnormal 50 ECU memory 59 Accelerator Position Sensor 60 YCCT malfunction 69 Front wheel speed sensor Now if it was code 019 then I could understand your situation (I can relate since I am occasionally dyslexic) https://fj-09.org/thread/1088/code-019 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
krupted Posted June 20, 2018 Author Share Posted June 20, 2018 I dont even see 091 on the list 12 Crankshaft Position sensor 13, 14, 20, 25, 26 Intake air pressure sensor 15 Throttle Position sensor 19 Kickstand Switch 21 Coolant temperature switch 22 Intake air temperature sensor 24 Oxygen sensor 30 & 41 Lean angle sensor 33, 34, and 35 Ignition coil 1, 2, and 3 respectively 39 Fuel Injector 42 Rear wheel speed sensor, clutch switch, or neutral switch 43 Fuel system voltage low 46 Charging voltage abnormal 50 ECU memory 59 Accelerator Position Sensor 60 YCCT malfunction 69 Front wheel speed sensor Now if it was code 019 then I could understand your situation (I can relate since I am occasionally dyslexic) https://fj-09.org/thread/1088/code-019 Thanks, ya, I'm pretty sure it was 091, but, maybe I am mixing up the numbers. Only explanation I can come up with. Thanks Current Ride - 2003 Kawasaki KLR650 Link to comment Share on other sites More sharing options...
fjdog Posted June 20, 2018 Share Posted June 20, 2018 As stated above There have been other threads about an error code 019 that have similar symptoms to what you are describing. If I remember correctly the solution/problem was the key was not turned fully in the ignition. I had the error 19 just twice and turning it off and on solved it for me. Link to comment Share on other sites More sharing options...
