justplainbill Posted October 14, 2018 Share Posted October 14, 2018 I stumbled on this article by Brad Hepler posted on the VFR forum several years ago. https://vfrworld.com/tex_vfr/tech/setup_2.htm It lists typical motorcycle suspension problems by symptoms, with possible causes and cures. For example: "Symptoms: Not using full travel, feels harsh, poor traction in bumpy corners Causes: Overly stiff springing or compression damping Solutions: Lower air pressure; reduce compression damping; softer coil springs" I guess VFR's were using air pressure on top of oil in the front forks when Hepler wrote the article. For our bikes, ignore that part of the write up. Printing the article (3 pages) gives you a handy guide to take (along with suitable tools) when making field adjustments to front and rear suspension units. Link to comment Share on other sites More sharing options...
tktplz Posted October 15, 2018 Share Posted October 15, 2018 I tried the link and this is what I got; This site can’t be reached The webpage at https://vfrworld.com/tex_vfr/tech/setup_2.htm%C2%A0 might be temporarily down or it may have moved permanently to a new web address. ERR_CONTENT_DECODING_FAILED Ain't no fun when the rabbit gets the gun! Link to comment Share on other sites More sharing options...
jonno12345 Posted October 15, 2018 Share Posted October 15, 2018 It should be: http://vfrworld.com/tex_vfr/tech/setup_2.htm Link to comment Share on other sites More sharing options...
justplainbill Posted October 15, 2018 Author Share Posted October 15, 2018 I tried the link and this is what I got; This site can’t be reached Not sure how that happened - but I re-pasted the link and it works now. Thanks. Link to comment Share on other sites More sharing options...
