  • Who's Online   0 Members, 0 Anonymous, 11 Guests (See full list)
How to remove mirror base 10mm nut?
sterlinggold
Thanks, yes I thought about that tool but could not find a 10mm, anyway I ground down a 10mm socket and realized you are not supposed to remove this nut, the bolt is pressed for a reason. This nut hold a tension spring for the mirror.
To remove the mirror you need to take the 17mm base off (reverse thread on right side).
I am trying to install these extenders, if you plan on getting make sure you order a kit that includes a 10mm reverse thread bolt.
