aussietracer Posted March 28, 2015 Share Posted March 28, 2015 Since taking ownership of my Tracer I had noticed the wobble in and out of corners, and the head wobble when getting on the gas any higher then 140kmh/86mph. The head wobble was so bad I could get it started with aggressive active countersteering (pushing on bars). Decided to tweak the suspension to see how it went. Tyres- Fr36psi, R38psi Rider- 90Kg with gear. Luggage- minimum. Forks Standard Settings- 16mm Compression, 7 clicks from full hard New Settings- 14mm Compression, 6 clicks from full hard Rear Shock. My shock didnt have markings but assuming they are set to standard like the forks... Standard Settings- 1.5 turns from full hard rebound, Setting 4 for preload/compression. New Settings- .5 turns from full hard rebound, Setting 6 for preload/compression. The bike handles itself better in the corners, particularly under throttle leaving the apex (no more bouncing). I couldn't induce head wobble, even under spirited throttle mid corner or on the straight. I might dial the rear back .5 turn, Set. 5 in the future but for the mean time the bike rides like my dearly departed Triumph. EDIT: Forgot to add, the TCS lights up a bit more getting on the gas, especially out of the corner, might be because the power isnt being lost to the rear shock. Link to comment Share on other sites More sharing options...
Premium Member wessie Posted March 28, 2015 Premium Member Share Posted March 28, 2015 do you set pressures lower in Oz due to the heat? For the UK the rear tyre pressure is 42psi, same front at 36psi This signature is left blank as the poster writes enough pretentious bollocks as it is. Link to comment Share on other sites More sharing options...
aussietracer Posted March 28, 2015 Author Share Posted March 28, 2015 I noticed in the book it asks for 42 on the rear but I've run all my bikes +2 on the rear. Might play with the rear in the future. Link to comment Share on other sites More sharing options...
Tracerforme Posted April 1, 2015 Share Posted April 1, 2015 Hi & welcome aussietracer! I noticed your previous bike was a 2015 STR, I must admit I looked at that same bike before the Yammy was released. Does the Triumph have wide bars similar to the Tracer? I'm asking this because maybe you're not used to having wider bars? Even the smallest inputs can induce massive steering wobbles especially under acceleration. Though, your suspension changes give me a baseline to begin with since we are about the same weight (prior to having beers) so I'll work with that. please continue to write reports on your progress from both an ownership & suspension perspective. Lucky you have yours now to enjoy it! Cheers, Steve Link to comment Share on other sites More sharing options...
aussietracer Posted April 1, 2015 Author Share Posted April 1, 2015 Cheers mate, the bars are very similar in length. I backed the rear susp off 1 click+ halfturn ccw and its brought the wobbles back at 160kmh+ and slight wobble getting hard into the corners. Again silly speeds and shenanigans so if you're sensible it won't do anything to narly. Link to comment Share on other sites More sharing options...
Tracerforme Posted April 1, 2015 Share Posted April 1, 2015 Ok aussietracer, its a bike that makes you do it often! Enjoy it any way it makes you smile! Ride safe and have fun. Cheers again, Steve Link to comment Share on other sites More sharing options...
b12ty Posted April 1, 2015 Share Posted April 1, 2015 Ok aussietracer, its a bike that makes you do it often! Enjoy it any way it makes you smile! Ride safe and have fun. Cheers again, Steve misquote Ty '05 Bandit 1200s ( Blue and White ) Bandit pic 2015 FJ-09 ( RED ) FJ-09 pic Link to comment Share on other sites More sharing options...
caribou Posted April 1, 2015 Share Posted April 1, 2015 I experienced same wobble, especially during +140 kph. Changed settings similarly as you (same weight and no luggage) and improvement is obvious! Link to comment Share on other sites More sharing options...
buckybuk Posted April 2, 2015 Share Posted April 2, 2015 Forks Standard Settings- 16mm Compression, 7 clicks from full hard New Settings- 14mm Compression, 6 clicks from full hard Rear Shock. My shock didnt have markings but assuming they are set to standard like the forks... Standard Settings- 1.5 turns from full hard rebound, Setting 4 for preload/compression. New Settings- .5 turns from full hard rebound, Setting 6 for preload/compression. Ok just making sure I have this straight. I'm no mechanic. I just want to make sure I made the correct adjustments that you made. I'm showing 5 lines on front preload... measures just above a half inch (0.551181) Rebound Turning clockwise to full hard. Then 6 clicks toward soft Rear rebound turn clockwise to full hard the one half turn toward soft Next to last one (6) on rear preload 2016 R1 2015 FJ-09-------SOLD 2002 Wr250F 2014 Concours Link to comment Share on other sites More sharing options...
aussietracer Posted April 3, 2015 Author Share Posted April 3, 2015 Hey bud I just saw you PM and quote lol. Everything so far is AOK, but the rear shock may be too stiff at set6, as it is my shock is at set4 (backed off from set5). I noticed the steering is less twitchy but no wobbles at set5, set4 is a equal compromise. Remember to do both forks for compression. Link to comment Share on other sites More sharing options...
grogsym Posted April 20, 2015 Share Posted April 20, 2015 Hey Aussietracer, I tried your settings at the weekend. I am about 90kg with the gear on; I find your settings an excellent starting point that I may try and refine to my own needs at some stage in the future. Never had a chance to try and provoke head wobble, but cruised quite comfortably at 90/95. Felt more composed in the corners and when accelerating and braking. Thanks for posting! Link to comment Share on other sites More sharing options...
Guest rszk Posted April 20, 2015 Share Posted April 20, 2015 I'm probably real close to 90kg with all gear, so I will try your settings too. I am able to induce headshake as well on spirited runs, doesn't bother me as I'm used to it as my K L R does it easily haha. Thanks for posting your settings! Link to comment Share on other sites More sharing options...
