carey Posted March 1, 2021 Share Posted March 1, 2021 Quote I will call BT to see whether this is an issue to use the larger fuse for charging. I guess I could always split the difference and use a 10A. I'd be curious what BT will say, but I've been doing this on multiple bikes, with both "regular" and LiPo batteries for years. I've never had a problem. Link to comment Share on other sites More sharing options...
mferring Posted March 1, 2021 Author Share Posted March 1, 2021 So Carey, you are saying you are using the 15A fuse with the BT? Link to comment Share on other sites More sharing options...
Premium Member sirepair Posted March 1, 2021 Premium Member Share Posted March 1, 2021 Here's what I did (though some will cringe at drilling holes!) Sorry for the sketch, but it best represents what I made. Made a little bracket that is mounted with 2 pop rivets in the "trough" on the left side. Secures the coax connector so connection will pull apart without damage to wiring. Tip: occasionally put some dielectric grease in the connector. I always seem to lose the caps! 1 Link to comment Share on other sites More sharing options...
