kroc Posted August 24, 2021 Share Posted August 24, 2021 Hi, somehow I managed to lose one of the small circular covers that sit in top of the mirror mounting posts on the left side of my 2015 FJ-09. Is this something that is available separately or does one need to order a whole new mirror assembly. Also are there any alternatives that one might consider? I have attached pics showing the missing circular cover on the clutch handle side of the bike as well as a pic of the throttle handle side with the cover still present. Thanks! Kelly Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted August 24, 2021 Premium Member Share Posted August 24, 2021 Did you check the parts fish to see if it's available if it isn't maybe maybe buy a used mirror online I've never had a problem with mine popping out but I'll keep an eye out now maybe some body side molding adhesive would be a good idea to prevent it from happening again Link to comment Share on other sites More sharing options...
Supporting Member knyte Posted August 24, 2021 Supporting Member Share Posted August 24, 2021 So it's not just me! I lost one, too...no idea where or how. I actually replaced both mirrors with aftermarket mirrors (can't tell the difference from stock) and for some reason the covers don't fit right - the bolt inside sticks up juuuust enough that the cover won't snap into place. Arg - first world problems? At worst a drop of black silicone or something should do the trick. Just anything that's easy to remove. 2015 FJ-09 / FJR touring bags / oil plug mod / Evotech rad guard / SW Motech bash plate / VStream touring windshield / Seat Concepts: Sport Touring / Vcyclenut ABS rings (speedo correction) / Cosmo RAM mount Link to comment Share on other sites More sharing options...
