duckie Posted September 29, 2021 Share Posted September 29, 2021 (edited) As far as I know, these will disengae CC…. using clutch using front brake using rear brake closing the throttle Up shifting using QS only not sure about s clutchless down shift….yes it can be done. To engage……. speed above 28ish mph and 4th gear unless these parameters were changed by a reflash. Each one of those needs to be checked for proper operation. I assuming that if in 4th and the speed drops below 28, that will disengage the CC. Trouble shooting is a process of elmination. Each one of the above must be eliminated as a possible source of the issue. Oh and the switch that turns on/off CC. Edited September 29, 2021 by duckie Link to comment Share on other sites More sharing options...
