Supporting Member piotrek Posted December 5, 2021 Supporting Member Share Posted December 5, 2021 3 hours ago, texscottyd said: That’s a valid point I hadn’t considered. That makes at least two of us. There was some language in my case. 1 Link to comment Share on other sites More sharing options...
Urs J Posted December 31, 2021 Share Posted December 31, 2021 For exchanging fluid you need nothing. Gravity drives out the old fluid. If you exchange for instance brake hoses and your system is completely empty, you need this: https://a.aliexpress.com/_vEpgKT With this tool you suck the smallest air bubbles out of the system. You need to suck out the fluid out and not press in. If you suck, the small hidden air bubbles grow in diameter and sneak out of the hidden corner of the system. 1 Link to comment Share on other sites More sharing options...
