flyfifer Posted February 3, 2022 Share Posted February 3, 2022 How do the brake pipe clips detach from the "fender" ?? Twist and pull ? Thinking about Pyramid Extender . Link to comment Share on other sites More sharing options...
skipperT Posted February 4, 2022 Share Posted February 4, 2022 You could, but you’ll possibly wreck them. They have 2 pieces that stick out just enough after they’ve been inserted into the hole, to prevent them from coming back out easily. you can squeeze them gently with a pair of needle nose while pulling them out of the fender. But it’s easier to do that with the fender or front tire removed. a small pick can also be used as you rock it first one direction and then the other… i don’t think these are the same as the FJ/Tracer ones, but they are similar. -Skip 1 Link to comment Share on other sites More sharing options...
flyfifer Posted February 4, 2022 Author Share Posted February 4, 2022 I realised that they would have "barbs" preventing them from falling out and as you say wheel out would be easy. I suspect that they are same/similar to the one being held. The image clearly shows a ratchet lock on the circular bit so I will have a go at splitting it open. Link to comment Share on other sites More sharing options...
bowlin01 Posted February 4, 2022 Share Posted February 4, 2022 (edited) 33 minutes ago, flyfifer said: I realised that they would have "barbs" preventing them from falling out and as you say wheel out would be easy. I suspect that they are same/similar to the one being held. The image clearly shows a ratchet lock on the circular bit so I will have a go at splitting it open. @flyfifer from memory when I fitted my extender you are correct, just undo the 'ratchet' (I used a small screwdriver). Edited February 4, 2022 by bowlin01 Link to comment Share on other sites More sharing options...
flyfifer Posted February 4, 2022 Author Share Posted February 4, 2022 (edited) Bowlin01, thanks for that. Story continued here. Edited February 7, 2022 by flyfifer Link to comment Share on other sites More sharing options...
