flyfifer Posted March 11, 2022 Share Posted March 11, 2022 Under seat. Main fuse: 50.0 A and Fuel injection system fuse: 20.0 A (remove the starter relay cover by pulling it up to access). The following are all Mini type Fuses. Under seat Fuse box 1: 1.Radiator fan motor :15.0 A 2.Backup fuse:7.5 A for clock and immobilizer. 3.Elect throttle valve :7.5A 4.ABS solenoid :15.0 A 5.ABS motor : 30.0 A 6. spare fuses. Fuse box 2 lhs :top to bottom. 12. Ignition :15.0 A 11. Spare fuse 10.Seat heater option: 7.5A 9. ABS control unit: 7.5A 8.Fog lamp option: 2.0A 7.Signaling system: 7.5A 6.Brake light :1.0 A Fuse box 3 rhs:top to bottom. 1.Parking lighting: 7.5 A 2.Headlight : 7.5 A 3. Aux connector under windscreen: 2.0A 4. 12v socket: 2.0A 5.Cruise control :1.0 A 11.Spare: 2.0 A 1 Link to comment Share on other sites More sharing options...
flyfifer Posted March 11, 2022 Share Posted March 11, 2022 Fuses. See page 101, section 6.32 of the manual. Fuse box 1 under the seat. Fuse boxes 2 and 3 behind Indicator Side panels (manual section 306.9, page 79, for side panel removal instructions).--- Remove three dzus screws. Pull panel out -- there is a push fit plug into a hole. Slide panel down to disengage a short tongue. Panel is now free, apart from indicator cable plug. 1 Link to comment Share on other sites More sharing options...
