Ride On Posted April 29, 2022 Share Posted April 29, 2022 Oil began spurting out of the head, just below the exhaust pipe. I'm thinking this "hole in the head" contains some sort of pressure relief or check valve. Anybody know for sure? I just serviced the valves and I'm wondering if an oil port got blocked off during reassembly. Thanks! Link to comment Share on other sites More sharing options...
peteinpa Posted April 29, 2022 Share Posted April 29, 2022 I think that goes to the spark plug recessed area so rain can drain out. Your valve cover gasket rolled on install. 4 Link to comment Share on other sites More sharing options...
skipperT Posted April 30, 2022 Share Posted April 30, 2022 Second peteinpa’s comment I’d add that if oil continues to come out of the hole, then the gasket is not correctly installed. it’s possible that it was only a bit of residual fluid that got in there that you didn’t notice. Clean, monitor and cross your fingers and give it some time. If leak continues, you’ll have to pull it apart. -Skip Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted April 30, 2022 Premium Member Share Posted April 30, 2022 If that's it, good call! Now I have to go look at the pics I took when I recently did my last major service which included having the plugs out. As offhand I don't recall a drain hole down there... Link to comment Share on other sites More sharing options...
Ride On Posted May 6, 2022 Author Share Posted May 6, 2022 On 4/29/2022 at 6:02 PM, peteinpa said: I think that goes to the spark plug recessed area so rain can drain out. Your valve cover gasket rolled on install. Thanks for the tip! That is exactly what happened. I pulled it all apart and found the gasket to be in great shape. I cleaned it up with alcohol and pressed the gasket in place with light coating of Yamahabond to hold it. In total, another 4 hours of work to get it right the second time. I took the attached pic prior to dissassembly. Sure enough, oil in the spark plug recess. 5 Link to comment Share on other sites More sharing options...
