exstowner Posted August 4, 2022 Share Posted August 4, 2022 I blew 2 fuses. The 1 amp and 7.5 amp fuse behind the right side faring. Now the check engine light is on. How do I clear that? Link to comment Share on other sites More sharing options...
bwringer Posted August 4, 2022 Share Posted August 4, 2022 It would help to know why the fuses blew, and whether that has been corrected. Link to comment Share on other sites More sharing options...
exstowner Posted August 4, 2022 Author Share Posted August 4, 2022 I was wiring a brake light for my golf club carrier and connected hot to ground. All the lights went out. Disconnected the new brake light, replaced the fuses and the lights are now working. But the check engine light came on once i started the engine. Link to comment Share on other sites More sharing options...
skipperT Posted August 4, 2022 Share Posted August 4, 2022 (edited) It’s strange that a MIL light would appear after that happened based on those 2 fuses being blown. But never underestimate what the ECM is programmed to throw up a light for- you’ll need to clear it with an OBDII reader and the appropriate res 6P adapter, or swing by your dealership. I’d be curious to know what code was triggered. I’m also suspicious that there isn’t still another fuse blown that you haven’t found yet - have you taken the bike for a ride since the work and does everything function properly? -Skip Edited August 4, 2022 by skipperT Link to comment Share on other sites More sharing options...
Cogswell Posted August 4, 2022 Share Posted August 4, 2022 43 minutes ago, exstowner said: I was wiring a brake light for my golf club carrier and connected hot to ground. All the lights went out. Disconnected the new brake light, replaced the fuses and the lights are now working. But the check engine light came on once i started the engine. Which two fuses blew ? I can understand the lighting circuit fuse blowing. Which hot wire did you short to ground ? Link to comment Share on other sites More sharing options...
exstowner Posted August 4, 2022 Author Share Posted August 4, 2022 Rear brake light is the one I ‘hot’ wired wrong. I checked all the fuses in that box and all are good. I rode the bike yesterday to the golf course and back (10 miles each way) and no issues. Link to comment Share on other sites More sharing options...
skipperT Posted August 4, 2022 Share Posted August 4, 2022 4 hours ago, exstowner said: Rear brake light is the one I ‘hot’ wired wrong. I checked all the fuses in that box and all are good. I rode the bike yesterday to the golf course and back (10 miles each way) and no issues. Then proceed as I outlined above to get the code cleared. -Skip 1 Link to comment Share on other sites More sharing options...
