ksim Posted May 11, 2023 Share Posted May 11, 2023 (edited) Need some advice please, Was trying to sync throttle bodies, but didn't touch the left painted screw, middle was kind of fine turning easily around 180-270 degrees easily, and stiff after, but was in sync with the left one in this range. But the right one was very stiff, I thought maybe corrosion, ordered a new screw set and got the old one out (the screw head got really damaged by doing that as the screw was very tight). tried the new one and it is also very stiff going in. Am I doing something wrong? Why screws are so tight? Edited May 11, 2023 by ksim Link to comment Share on other sites More sharing options...
ksim Posted May 12, 2023 Author Share Posted May 12, 2023 4 hours ago, Heli ATP said: Model, Year, Miles? Tracer 900 GT 2018 27k Link to comment Share on other sites More sharing options...
johnmark101 Posted May 12, 2023 Share Posted May 12, 2023 Not certain but I think one of the screws is fixed and not to be turned while the others are adjusted to match. Someone correct me if this is wrong. There is nothing like spending a day riding with friends in the grip of a shared obsession. Link to comment Share on other sites More sharing options...
ksim Posted May 12, 2023 Author Share Posted May 12, 2023 I haven't touched the painted (left) one, but 2 others are really hard to turn. Link to comment Share on other sites More sharing options...
RaYzerman Posted May 12, 2023 Share Posted May 12, 2023 (edited) They shouldn't be hard to turn, but sometimes brass and aluminum can develop bi-metal corrosion...... however, once moving, one can hope they turn easier. What I recommend is to remove the throttle bodies for better access, and with a better screwdriver, note position and number of turns to remove. If you remove the painted one, be sure to count and put it back to where it was. I'm not sure whether on this bike Yamaha sets the reference screw fully in or not (as is on the FJR with throttle by wire)...... In any event, remove the screws and put a light coating of grease on the threads, that should fix you up. It may be possible the extra hard one was fully seated. IF your throttle sync was still a bit off (wishing you could turn it in more), then leave that one seated (your new reference) and back off the others to get a match, even if the painted one must be moved out somewhat (likely not much, maybe 1/8-1/4 turn). It just means your new reference screw is the one that's fully seated (again, if that was the intent for one to be seated as reference). The whole idea is to have them sync'ed evenly. Edited May 12, 2023 by RaYzerman Link to comment Share on other sites More sharing options...
ksim Posted May 12, 2023 Author Share Posted May 12, 2023 thank you, applied silicone grease and slowly turned the screw in, middle one got out using a good screwdriver which fits the slot perfectly, applied silicone grease also and got it back, adjected the bodies, seems fine now, will see how it works on road. didn't need to touch the left painted screw. Link to comment Share on other sites More sharing options...
bwringer Posted May 12, 2023 Share Posted May 12, 2023 IIRC, these screws have some sort of gooey thread locking compound to sort of gum up the works so they'll stay put. IOW, I think they're supposed to be somewhat hard to turn due to sticky schmutz in the threads that keeps them from turning when they're not supposed to. You never need to turn them very far, if at all, so there's no reason to worry if they're not easy to turn. 1 Red 2015 FJ-09, among other things. Co-Host of The Riding Obsession, a Sport-Touring Motorcycling Podcast Link to comment Share on other sites More sharing options...
RaYzerman Posted May 13, 2023 Share Posted May 13, 2023 There is no thread locking compound, the screw assembly consists of a tiny brass washer and o-ring, a spring, and the screw. The screw is held in place by spring pressure........ same concept on every bike. 2 Link to comment Share on other sites More sharing options...
bwringer Posted May 13, 2023 Share Posted May 13, 2023 Huh, coulda sworn mine were gooey, too. Maybe that was a gift from the PO or the shop he used. Red 2015 FJ-09, among other things. Co-Host of The Riding Obsession, a Sport-Touring Motorcycling Podcast Link to comment Share on other sites More sharing options...
