dndfindley Posted May 28, 2015 Share Posted May 28, 2015 Recently someone posted they used a Cable Cuff for cruise control but did not explain how they used it. Does anyone know? Link to comment Share on other sites More sharing options...
odisspunkmuer Posted May 29, 2015 Share Posted May 29, 2015 Recently someone posted they used a Cable Cuff for cruise control but did not explain how they used it. Does anyone know? From the looks of the picture you're referring too, it looks like he taped a rod of some sort to the cable cuff to act as the brace against the brake lever(to hold the throttle open). There also looks to be electric tape on the throttle grip to let the grip slide within the cuff when engaged so you can kill the throttle when it's locked. I'd assume you engage the cuff on the grip like you would normally on...a cable. I'd personally say spend 30 bucks on a go cruise or something that's DESIGNED for throttle locking, with safety in mind. I feel like if you can spend 11k on a brand new bike, you can spend $30 on a proper throttle lock, but that's your call. Good luck mate, cheers. Link to comment Share on other sites More sharing options...
sixcharlie Posted May 29, 2015 Share Posted May 29, 2015 I have a go cruise, inexpensive, good looking and works great. http://www.2wheelride.com/GoCruise_throttle%20control2.html Link to comment Share on other sites More sharing options...
sixcharlie Posted May 29, 2015 Share Posted May 29, 2015 Link to comment Share on other sites More sharing options...
19ab Posted May 29, 2015 Share Posted May 29, 2015 Recently someone posted they used a Cable Cuff for cruise control but did not explain how they used it. Does anyone know? From the looks of the picture you're referring too, it looks like he taped a rod of some sort to the cable cuff to act as the brace against the brake lever(to hold the throttle open). There also looks to be electric tape on the throttle grip to let the grip slide within the cuff when engaged so you can kill the throttle when it's locked. I'd assume you engage the cuff on the grip like you would normally on...a cable. I'd personally say spend 30 bucks on a go cruise or something that's DESIGNED for throttle locking, with safety in mind. I feel like if you can spend 11k on a brand new bike, you can spend $30 on a proper throttle lock, but that's your call. Good luck mate, cheers. Cable cuff locked on a last tooth works exactly like go-cruise at desired speed push it with your thumb against brake lever ,the cable cuff was a temporary solution made by me in 5 minutes , till my go-cruise came in Link to comment Share on other sites More sharing options...
dndfindley Posted June 1, 2015 Author Share Posted June 1, 2015 Thanks for all the replies. All of you are correct in that it would be better to spend the extra money and get something that is proven to work in lieu of a plastic piece that may be trouble. Link to comment Share on other sites More sharing options...
