cameron12x Posted January 26, 2015 Share Posted January 26, 2015 Has anyone purchased the Yamaha rear rack? If so, how easy was it to install? How long? TIA. Link to comment Share on other sites More sharing options...
cthruu Posted January 26, 2015 Share Posted January 26, 2015 Easy- 15 minutes tops. Just need to undo the 4 bolts for the saddlebag racks and the 2 bolts for the handholds and bolt it together. I just found another rear rack if your interested. Its on the European facebook page and its their oem accessories I think. https://www.facebook.com/mt09tracer 2015 FJ-09 2004 KTM 525 Link to comment Share on other sites More sharing options...
fjjouster Posted January 26, 2015 Share Posted January 26, 2015 Easy- 15 minutes tops. Just need to undo the 4 bolts for the saddlebag racks and the 2 bolts for the handholds and bolt it together. I just found another rear rack if your interested. Its on the European facebook page and its their oem accessories I think. https://www.facebook.com/mt09tracer wheredo we find these in america!!!! i need these parts Link to comment Share on other sites More sharing options...
skunkmilk Posted January 29, 2015 Share Posted January 29, 2015 Got my rack on fleabay. Just got it today. Haven't installed it yet. I paid slightly less than msrp, but since it seems like everything is on back order these days I decided I better get it "while supplies last"... Link to comment Share on other sites More sharing options...
nowheelies Posted January 29, 2015 Share Posted January 29, 2015 Got my rack on fleabay. Just got it today. Haven't installed it yet. I paid slightly less than msrp, but since it seems like everything is on back order these days I decided I better get it "while supplies last"... curious about the mt-09 tracer rack. looks good from the fb pic. is that the one you ordered? Link to comment Share on other sites More sharing options...
skunkmilk Posted January 29, 2015 Share Posted January 29, 2015 It looks like this: http://tinyurl.com/qxvfp6f Link to comment Share on other sites More sharing options...
Rahza Posted January 29, 2015 Share Posted January 29, 2015 Easy- 15 minutes tops. Just need to undo the 4 bolts for the saddlebag racks and the 2 bolts for the handholds and bolt it together. I just found another rear rack if your interested. Its on the European facebook page and its their oem accessories I think. https://www.facebook.com/mt09tracer Another link, to a Norwegian dealer (I think it's the importer of Yamahas): http://yamahamc.com/collections/yamaha-originalutstyr/mt-09-tracer Link to comment Share on other sites More sharing options...
cameron12x Posted January 30, 2015 Author Share Posted January 30, 2015 Thanks everyone for the heads-up. I ordered one from eBay here: Rear Rack I just found another one! Another Rear Rack Do a Google search on this part number: 2PP-F48D0-V0-00 Google Search for Rear Rack Hope this helps! Link to comment Share on other sites More sharing options...
philkin Posted February 4, 2015 Share Posted February 4, 2015 Can you verify if the rack will accept the standard FJR trunk. Not that I will do that. I have a Givi trunk that I would like to use. I am assuming, if so, the Givi adapter plate for the FJR will connect to this rear rack also. Link to comment Share on other sites More sharing options...
redfjniner Posted February 5, 2015 Share Posted February 5, 2015 Can you verify if the rack will accept the standard FJR trunk. Not that I will do that. I have a Givi trunk that I would like to use. I am assuming, if so, the Givi adapter plate for the FJR will connect to this rear rack also. Phil, it looks like the rear rack is set up for Yamaha top trunks. Slightly different connection than Givi. That is not saying that you couldn't remove the Yamaha plastic rack and adapt a Givi mounting plate. You might be better off just waiting for Givi to come out with a rear rack for their top cases. They do a good job on these. Ken, Candy Ass L.D.R. Sleeps 8 hours (2)2005 FJR1300abs: 230,000 m 2015 FJ-09: 106,000 m (Lost compression in #2 Cyl.) Link to comment Share on other sites More sharing options...
vespadaddy Posted February 5, 2015 Share Posted February 5, 2015 Can you verify if the rack will accept the standard FJR trunk. Not that I will do that. I have a Givi trunk that I would like to use. I am assuming, if so, the Givi adapter plate for the FJR will connect to this rear rack also. Phil, it looks like the rear rack is set up for Yamaha top trunks. Slightly different connection than Givi. That is not saying that you couldn't remove the Yamaha plastic rack and adapt a Givi mounting plate. You might be better off just waiting for Givi to come out with a rear rack for their top cases. They do a good job on these. This begs the question: Are Givi or Shad boxes any better than the factory Yamaha trunks? FWIW, I intend to buy the factory sidecases, and also fit a trunk with enough capacity to hold 2 full face helmets. I'm very interested in hearing if others are also planning to buy a trunk, and how others feel the Yamaha top case compares to the offerings from Shad and Givi. Link to comment Share on other sites More sharing options...
yamaham Posted February 5, 2015 Share Posted February 5, 2015 I have a Givi mount plate on Yammie rear rack no problem getting it to work. Link to comment Share on other sites More sharing options...
2damax Posted February 5, 2015 Share Posted February 5, 2015 yamaham, any pictures of the Givi rack? Thanks Link to comment Share on other sites More sharing options...
redfjniner Posted February 5, 2015 Share Posted February 5, 2015 This begs the question: Are Givi or Shad boxes any better than the factory Yamaha trunks? FWIW, I intend to buy the factory sidecases, and also fit a trunk with enough capacity to hold 2 full face helmets. I'm very interested in hearing if others are also planning to buy a trunk, and how others feel the Yamaha top case compares to the offerings from Shad and Givi. I have been using a $50 JCWhitney top box for the last 8 years. I has been performing Excellent. I painted the top lid to match the bike and it looks great. Not as refined as the Givi or Shad but it does the job. All these top boxes look to big on the FJ, IMO. Had to add that bit on personal aesthetic opinion. Based on putting one of my 46 liter top boxes on the rear rack. Side bags look to big too. I will ride with a smaller tail bag most of the time, only using the side bags when on trips. Pic of a JCWhitney top box painted to match bike on a FJR. Ken, Candy Ass L.D.R. Sleeps 8 hours (2)2005 FJR1300abs: 230,000 m 2015 FJ-09: 106,000 m (Lost compression in #2 Cyl.) Link to comment Share on other sites More sharing options...
cameron12x Posted February 6, 2015 Author Share Posted February 6, 2015 I too had one of those JC Whitney top cases on a different V-Strom I owned. It worked well enough for my intended purposes. I wonder if they will fit on the FJ-09 :-/ EDIT: I just ordered this one: http://www.jcwhitney.com/p2010969/sku-346516.jcwx (Copy and paste into browser; link doesn't work for some strange reason.) I ordered the smaller one as I think the large one will look too big and I don't think I need that much space. There is a special deal running through tomorrow: Free shipping and 10% off your purchase if you use this promo code: 1SW2015 So, my OTD price was a whopping: $38.03 Read all of the reviews before ordering. But at this price, the risk is pretty low. I'll post again in a few weeks after it has arrived, I've installed it (hopefully it will install), and I've ridden with it. Given it's Winter, I'm not sure when I'm going to be able to ride again here in central Ohio. Link to comment Share on other sites More sharing options...
