paulsmith Posted April 26, 2016 Share Posted April 26, 2016 I can't believe that in 3 pages of suggestions for this problem, the most common issue for a clunky shift hasn't been mentioned. Make sure your clutch lever is adjusted correctly. Especially with a new bike, the clutch cable is going to stretch quite a bit and need regular adjustment for a while.A stretching or mis-adjusted clutch cable would change the bite point of the clutch but I don't see how it would affect the quality of the gear change? Link to comment Share on other sites More sharing options...
Guest dmizer Posted April 26, 2016 Share Posted April 26, 2016 A stretching or mis-adjusted clutch cable would change the bite point of the clutch but I don't see how it would affect the quality of the gear change? If the clutch is not fully disengaging, it will drag a bit and make the shift more difficult. Link to comment Share on other sites More sharing options...
