buckybuk Posted June 12, 2016 Share Posted June 12, 2016 I removed and cleaned the 02 sensor but to no avail. Engine light still on.. My question is, once I replace the 02 Sensor will it clear itself or will I be forced to go to stealership to have them reset ? 2016 R1 2015 FJ-09-------SOLD 2002 Wr250F 2014 Concours Link to comment Share on other sites More sharing options...
sxx360 Posted June 13, 2016 Share Posted June 13, 2016 Once you replace the sensor it should clear itself. Link to comment Share on other sites More sharing options...
Premium Member wessie Posted June 13, 2016 Premium Member Share Posted June 13, 2016 The fault should go away if it is fixed by a new sensor - I'd check the wiring before buying a new part. The ECU remembers previous faults so someone with the right kit can get a history. Useful if trying to locate an intermittent fault. This signature is left blank as the poster writes enough pretentious bollocks as it is. Link to comment Share on other sites More sharing options...
buckybuk Posted June 13, 2016 Author Share Posted June 13, 2016 Have bike torn apart now. Followed the o2 sensor from plug and wire disappears into a larger harness. From all indication everything looks fine. Obviously all parts fail. Just a little unusual at 9600 miles..... You seen o2 sensors fail this fast ? 2016 R1 2015 FJ-09-------SOLD 2002 Wr250F 2014 Concours Link to comment Share on other sites More sharing options...
jsp Posted June 14, 2016 Share Posted June 14, 2016 I removed and cleaned the 02 sensor but to no avail. Engine light still on.. My question is, once I replace the 02 Sensor will it clear itself or will I be forced to go to stealership to have them reset ? I believe the O2 sensor is covered by the Yamaha Emission coverage mandated by the Federal Government if you are in the U.S. john Link to comment Share on other sites More sharing options...
buckybuk Posted June 18, 2016 Author Share Posted June 18, 2016 Wow thanks 2016 R1 2015 FJ-09-------SOLD 2002 Wr250F 2014 Concours Link to comment Share on other sites More sharing options...
buckybuk Posted June 18, 2016 Author Share Posted June 18, 2016 Looked into it and it seems as it is indeed covered if I reside in a county that requires emissions testing to pass inspection. And I don't....... Will it hurt to keep riding this bike with a bad sensor until I can get another ? 2016 R1 2015 FJ-09-------SOLD 2002 Wr250F 2014 Concours Link to comment Share on other sites More sharing options...
Premium Member britelitebob Posted June 18, 2016 Premium Member Share Posted June 18, 2016 Sometimes if you briefly disconnect the battery the codes will reset, and I wouldn't worry about riding it as long as it's running normal. BLB Link to comment Share on other sites More sharing options...
