Buggy Nate Posted May 20, 2017 Share Posted May 20, 2017 Has anyone who has wired up their fog light/spotlights L.E.D light bar relay being switched off the ECU's Y/B earth switched wire had any issues? I just recently read here that some one had a issue with the controller in the ECU dying for that circuit.. Just a little worried about doing it that way now even though it has to be switched off the High beam and a separate switch in Australia for road use. I wouldn't have thought a normal low powered relay would cause this issue though?? Link to comment Share on other sites More sharing options...
xlxr Posted May 20, 2017 Share Posted May 20, 2017 https://fj-09.org/thread/5324/wire-front-leds-help-sought There is a technical explanation in this thread, I think that is the answer your are looking for. Link to comment Share on other sites More sharing options...
Buggy Nate Posted May 22, 2017 Author Share Posted May 22, 2017 https://fj-09.org/thread/5324/wire-front-leds-help-sought There is a technical explanation in this thread, I think that is the answer your are looking for. Cheers matey, was more curious whether it had affected more than one person so far, I think I will just wire mine up with one switch to be on the safe side... Link to comment Share on other sites More sharing options...
