  • Who's Online   0 Members, 0 Anonymous, 24 Guests (See full list)
Proper fitment of gas tank coupler
Hi all.  I removed my gas tank for changing of the air filter & plugs.  Just want to be sure the gas tank coupler (at the fuel pump) is on all the way.  If someone could post a photo you may have or instructions it would be appreciated.  Thank you!
After you push the fitting of the line on the fuel pump, and close the clip - cycle the key (with the run switch on and pump plugged in). The pump runs for 4 seconds key on.
Watch your eyes if you’re worried about the connection. If no leaks are seen, good to go.
I don’t have a pic handy sorry.
A very light coating of oil helps the seal inside the fuel line, slide easily onto the pump connection.
-Skip.
