Premium Member coachluciano Posted November 5, 2018 Premium Member Share Posted November 5, 2018 I’m in the process of swapping my stock handlebars with some nice Rizomas which are an inch shorter each side. That’s 2 full inches for those of you studying “common core” math. The part number for the FZ clutch (2015) cable is different than the FJ cable. Does anyone know if that is due to a shorter handlebar? 2015 FJ-09 - Andreani Cartridges, Ohlins 535 Rear Shock, LightTech Chain Adjusters, Yoshi Fender Eliminator, Blaster-X Integrated Tail Light/Blinkers, Full Yoshi Exhaust, Ivan's Flash, Bagster Seat, Rizoma: (Bar, Grips, Bar Ends, Mirrors, Oil Cap, Rear Pegs) Bremob Corsa Corta Master Cylinder, Bremob RCS19 Hadraulic Clutch, GPR Steering Damper, Speigler Hydraulic Lines, EBC Brake Pads, Puig Screen, HealTech Quick Shifter, MPG Rearset, XSR900 Slipper Clutch, Driven Racing Halo Gas Cap, SW-Motch Front / Rear Axel Sliders, R1 Rotors / 320mm Kit Conversion. Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted November 5, 2018 Supporting Member Share Posted November 5, 2018 I also have a Rizoma bars on my FJ, I cut and additional 15 mm off each side. The stock FJ clutch cable works just fine, no need to get a new one. ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
thepmh Posted November 6, 2018 Share Posted November 6, 2018 If your cable is still good, I would just use that same one. If you needed to replace it anyways, I would stick with a FJ cable, because the "risers" from the triple tree to the bar is taller on the FJ, I believe. Link to comment Share on other sites More sharing options...
Premium Member coachluciano Posted November 6, 2018 Author Premium Member Share Posted November 6, 2018 If your cable is still good, I would just use that same one. If you needed to replace it anyways, I would stick with a FJ cable, because the "risers" from the triple tree to the bar is taller on the FJ, I believe.Ah. Good point. I never thought of the height. Thanks. 2015 FJ-09 - Andreani Cartridges, Ohlins 535 Rear Shock, LightTech Chain Adjusters, Yoshi Fender Eliminator, Blaster-X Integrated Tail Light/Blinkers, Full Yoshi Exhaust, Ivan's Flash, Bagster Seat, Rizoma: (Bar, Grips, Bar Ends, Mirrors, Oil Cap, Rear Pegs) Bremob Corsa Corta Master Cylinder, Bremob RCS19 Hadraulic Clutch, GPR Steering Damper, Speigler Hydraulic Lines, EBC Brake Pads, Puig Screen, HealTech Quick Shifter, MPG Rearset, XSR900 Slipper Clutch, Driven Racing Halo Gas Cap, SW-Motch Front / Rear Axel Sliders, R1 Rotors / 320mm Kit Conversion. Link to comment Share on other sites More sharing options...
