Premium Member coachluciano Posted June 10, 2019 Premium Member Share Posted June 10, 2019 Question, I have upgraded cartridges in my front shocks been riding them for probably 3k miles. They work great especially with the 535 rear shock. Sitting still and grabbing the front brake and pulling up hard on the handle bars the back down, shocks are smooth as hell, but I hear small clunks when I do that. Wondering if it’s normal. knowing what is inside the the shock tubes I’m struggling to figure out what is causing it. I’m not overly concerned, unless I hear otherwise for the folks here. Andreani inserts. Any insight would be worth a beer or two. 2015 FJ-09 - Andreani Cartridges, Ohlins 535 Rear Shock, LightTech Chain Adjusters, Yoshi Fender Eliminator, Blaster-X Integrated Tail Light/Blinkers, Full Yoshi Exhaust, Ivan's Flash, Bagster Seat, Rizoma: (Bar, Grips, Bar Ends, Mirrors, Oil Cap, Rear Pegs) Bremob Corsa Corta Master Cylinder, Bremob RCS19 Hadraulic Clutch, GPR Steering Damper, Speigler Hydraulic Lines, EBC Brake Pads, Puig Screen, HealTech Quick Shifter, MPG Rearset, XSR900 Slipper Clutch, Driven Racing Halo Gas Cap, SW-Motch Front / Rear Axel Sliders, R1 Rotors / 320mm Kit Conversion. Link to comment Share on other sites More sharing options...
koth442 Posted June 10, 2019 Share Posted June 10, 2019 On other bikes, I've hard folks say the bearings in the head stem are making the noise. I've not confirmed this personally. '15 FJ09 Link to comment Share on other sites More sharing options...
Premium Member coachluciano Posted June 10, 2019 Author Premium Member Share Posted June 10, 2019 I’m going to get a video with sound (obviously) posted. I ride too fast to have an unknown possible issue in my front shocks. I’m not a huge fan of either Yamaha dealer near me especially when it comes to stuff like this. I’ve learned more on this site than any one general dealer mechanic has in the brain matter area when it comes to the -09 2015 FJ-09 - Andreani Cartridges, Ohlins 535 Rear Shock, LightTech Chain Adjusters, Yoshi Fender Eliminator, Blaster-X Integrated Tail Light/Blinkers, Full Yoshi Exhaust, Ivan's Flash, Bagster Seat, Rizoma: (Bar, Grips, Bar Ends, Mirrors, Oil Cap, Rear Pegs) Bremob Corsa Corta Master Cylinder, Bremob RCS19 Hadraulic Clutch, GPR Steering Damper, Speigler Hydraulic Lines, EBC Brake Pads, Puig Screen, HealTech Quick Shifter, MPG Rearset, XSR900 Slipper Clutch, Driven Racing Halo Gas Cap, SW-Motch Front / Rear Axel Sliders, R1 Rotors / 320mm Kit Conversion. Link to comment Share on other sites More sharing options...
Premium Member coachluciano Posted June 10, 2019 Author Premium Member Share Posted June 10, 2019 4 minutes ago, coachluciano said: I’m going to get a video with sound (obviously) posted. I ride too fast to have an unknown possible issue in my front shocks. I’m not a huge fan of either Yamaha dealer near me especially when it comes to stuff like this. I’ve learned more on this site than any one general dealer mechanic has in the brain matter area when it comes to the -09 Now that I think about it idiot Lucky Luciano, no speed is good with potential front suspension issues. 2015 FJ-09 - Andreani Cartridges, Ohlins 535 Rear Shock, LightTech Chain Adjusters, Yoshi Fender Eliminator, Blaster-X Integrated Tail Light/Blinkers, Full Yoshi Exhaust, Ivan's Flash, Bagster Seat, Rizoma: (Bar, Grips, Bar Ends, Mirrors, Oil Cap, Rear Pegs) Bremob Corsa Corta Master Cylinder, Bremob RCS19 Hadraulic Clutch, GPR Steering Damper, Speigler Hydraulic Lines, EBC Brake Pads, Puig Screen, HealTech Quick Shifter, MPG Rearset, XSR900 Slipper Clutch, Driven Racing Halo Gas Cap, SW-Motch Front / Rear Axel Sliders, R1 Rotors / 320mm Kit Conversion. Link to comment Share on other sites More sharing options...
BBB Posted June 11, 2019 Share Posted June 11, 2019 My modified front forks are much noisier than OEM, with loud sucking noises if I hold the front brake and bounce the shocks. This is due to the larger holes in the cartridges allowing much more fluid movement. I wonder if your noises are related to that and perhaps the little one-way valves clicking shut when the fluid direction flow reverses? 1 Red 2015 Tracer, UK spec (well, it was until I started messing with it...) Link to comment Share on other sites More sharing options...
Premium Member coachluciano Posted June 14, 2019 Author Premium Member Share Posted June 14, 2019 Thanks for all the replies. Yes, it’s actually the fluid moving. Not sure why it jumped out to me as something I should be concerned about and why it was so loud that day. And yes, way louder than stock when it comes to pushing fluid though small holes. 2015 FJ-09 - Andreani Cartridges, Ohlins 535 Rear Shock, LightTech Chain Adjusters, Yoshi Fender Eliminator, Blaster-X Integrated Tail Light/Blinkers, Full Yoshi Exhaust, Ivan's Flash, Bagster Seat, Rizoma: (Bar, Grips, Bar Ends, Mirrors, Oil Cap, Rear Pegs) Bremob Corsa Corta Master Cylinder, Bremob RCS19 Hadraulic Clutch, GPR Steering Damper, Speigler Hydraulic Lines, EBC Brake Pads, Puig Screen, HealTech Quick Shifter, MPG Rearset, XSR900 Slipper Clutch, Driven Racing Halo Gas Cap, SW-Motch Front / Rear Axel Sliders, R1 Rotors / 320mm Kit Conversion. Link to comment Share on other sites More sharing options...
3banger Posted June 19, 2019 Share Posted June 19, 2019 Also likely the front brake rotor rocking back and forth on its floating mounts. Link to comment Share on other sites More sharing options...
Premium Member coachluciano Posted June 19, 2019 Author Premium Member Share Posted June 19, 2019 Yup - in fact it's a combination of all the answers I got back. I guess I was overly paranoid that day. I hopped on a new 2020 the other day and ran the same test. Yes, the Andreani cartridges move much more fluid and it's noticeably louder. Thanks for all the replies 1 2015 FJ-09 - Andreani Cartridges, Ohlins 535 Rear Shock, LightTech Chain Adjusters, Yoshi Fender Eliminator, Blaster-X Integrated Tail Light/Blinkers, Full Yoshi Exhaust, Ivan's Flash, Bagster Seat, Rizoma: (Bar, Grips, Bar Ends, Mirrors, Oil Cap, Rear Pegs) Bremob Corsa Corta Master Cylinder, Bremob RCS19 Hadraulic Clutch, GPR Steering Damper, Speigler Hydraulic Lines, EBC Brake Pads, Puig Screen, HealTech Quick Shifter, MPG Rearset, XSR900 Slipper Clutch, Driven Racing Halo Gas Cap, SW-Motch Front / Rear Axel Sliders, R1 Rotors / 320mm Kit Conversion. Link to comment Share on other sites More sharing options...
