bubba Posted April 4, 2015 Share Posted April 4, 2015 I purchased some aftermarket adjustable levers for my last bike and never installed them as I wasn't sure how. I find the FJ-09's clutch lever requires a King Kong sized hand to operate and would like to replace it with the aftermarket ones. I would greatly appreciate if a fellow forum member could post step by step instructions, with lots of pictures, as to how to do this. Thanks in advance and if I ever meet you in person then a few pints are on me Link to comment Share on other sites More sharing options...
bubba Posted April 6, 2015 Author Share Posted April 6, 2015 Found this on Youtube for the FZ-09 which should be the same as the FJ-09. Looks simple, no rocket science degree required. Link to comment Share on other sites More sharing options...
Premium Member jimf Posted April 6, 2015 Premium Member Share Posted April 6, 2015 Found this on Youtube for the FZ-09 which should be the same as the FJ-09. Looks simple, no rocket science degree required. On every bike I've ever owned you basically remove the pivot bolt, remove the lever, and on the clutch side you have to work the cable end out of its slot. There may be a sleeve bearing around the bolt that has to be moved to the new lever, and you should grease that up. Other than that, assembly is the reverse of disassembly. It should take no more than 10 minutes to do this, if that long. There aren't many repair or upgrade tasks on a motorcycle that are easier. By the way, I just bought the very levers shown in that video. Now I'm just waiting for the bike so I can actually mount them.... 2015 FJ-09 (Mary Kate) 2007 Daytona 675 (Tabitha, ret.) 1998 Vulcan 800 (Ret.) 2001 SV650S (Veronica, Ret.) 2000 Intruder 800 (Ret.) Link to comment Share on other sites More sharing options...
efjay Posted April 22, 2015 Share Posted April 22, 2015 Youtube is full of instruction on changing levers. I did my last bike by watching those said videos. It was actually very simple. Link to comment Share on other sites More sharing options...
bubba Posted May 28, 2015 Author Share Posted May 28, 2015 I installed these today http://www.ebay.com/itm/271555487076?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT Very impressive quality. First time for me using shorty levers and I like them a lot. The range of adjustment is very good too. Almost identical install process to the youtube video posted above except remove the 2 hex screws for the hand guard mounts on either side of the handlebar and loosen the mirror stalks. Need a flat blade screwdriver, a deep 10 mm socket and some grease. No need to remove the plastic turn signal housing. 5 minutes to do each lever. Link to comment Share on other sites More sharing options...
silverninja Posted July 19, 2017 Share Posted July 19, 2017 Yes needing that DEEP 10mm socket threw me off - so it's off to the auto parts store for that...... Link to comment Share on other sites More sharing options...
carnuts88 Posted December 3, 2017 Share Posted December 3, 2017 Just wondering how those levers worked out. Is the quality OK?. Thinking about getting them. thanks Link to comment Share on other sites More sharing options...
