EJD87 Posted May 12, 2023 Share Posted May 12, 2023 I’m at wits’ end. I have no idea what to do. The new clutch plate stack is within spec. We’ve installed EVERYTHING correctly. Although I’m using the original part number clutch cable (the one with the weird bend that frays the cable over time), this shouldn’t affect the bike’s ability to disengage the clutch with the lever in, especially since it’s been adjusted to be as tight as possible, and I had no issue with it previously. I think it might be something having to do with the push lever assembly that engages with the push rod. It seems to “lock” instead of bringing the push rod and clutch plates out away from the engine. We can’t feel that spring tension. What could possibly be happening here? Link to comment Share on other sites More sharing options...
EJD87 Posted May 12, 2023 Author Share Posted May 12, 2023 12 minutes ago, EJD87 said: I’m at wits’ end. I have no idea what to do. The new clutch plate stack is within spec. We’ve installed EVERYTHING correctly. Although I’m using the original part number clutch cable (the one with the weird bend that frays the cable over time), this shouldn’t affect the bike’s ability to disengage the clutch with the lever in, especially since it’s been adjusted to be as tight as possible, and I had no issue with it previously. I think it might be something having to do with the push lever assembly that engages with the push rod. It seems to “lock” instead of bringing the push rod and clutch plates out away from the engine. We can’t feel that spring tension. What could possibly be happening here? To clarify, it seems I’m unable to unload the transmission at all after putting in this god-forsaken “upgrade,” rendering the bike unusable. Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted May 13, 2023 Premium Member Share Posted May 13, 2023 I'll bite I installed one in my fastest red 15 years ago and it's worked great since So to go out on limb You did something wrong 😎 Link to comment Share on other sites More sharing options...
EJD87 Posted May 13, 2023 Author Share Posted May 13, 2023 9 minutes ago, 2and3cylinders said: I'll bite I installed one in my fastest red 15 years ago and it's worked great since So to go out on limb You did something wrong 😎 Wow, what a profoundly useful comment. 1 2 Link to comment Share on other sites More sharing options...
Supporting Member dazzler24 Posted May 13, 2023 Supporting Member Share Posted May 13, 2023 8 hours ago, EJD87 said: I think it might be something having to do with the push lever assembly that engages with the push rod. It seems to “lock” instead of bringing the push rod and clutch plates out away from the engine. We can’t feel that spring tension. What could possibly be happening here? That was my first thought on reading this. I'll find the technique I used when reinstalling the clutch cover to ensure that the push rod engaged correctly with the lever. I'll be back....... OK here is my post on how I aligned things to get a working clutch. HTHs EDIT: - there's other advice tips in that thread from the learned community that may/should help as well. Good luck. 5 Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted May 13, 2023 Premium Member Share Posted May 13, 2023 5 hours ago, EJD87 said: Wow, what a profoundly useful comment. I'm always here to lend a hand. Another suggestion Start over... Link to comment Share on other sites More sharing options...
bwringer Posted May 13, 2023 Share Posted May 13, 2023 (edited) 10 hours ago, dazzler24 said: That was my first thought on reading this. I'll find the technique I used when reinstalling the clutch cover to ensure that the push rod engaged correctly with the lever. I'll be back....... OK here is my post on how I aligned things to get a working clutch. HTHs EDIT: - there's other advice tips in that thread from the learned community that may/should help as well. Good luck. Yep, it took me three tries to get this right too. I think your answer lies somewhere in there. You have to get the arm clocked just right, while juggling the tension of the spring on the cable, etc. No shame in it, and FWIW, the gasket will be just fine during multiple on/off cycles. Where y'at? Maybe there's someone nearby who's bored and been through this. Edited May 13, 2023 by bwringer 2 Red 2015 FJ-09, among other things. Co-Host of The Riding Obsession, a Sport-Touring Motorcycling Podcast Link to comment Share on other sites More sharing options...
