Headgas Posted June 23, 2023 Author Share Posted June 23, 2023 On 6/21/2023 at 12:23 PM, 2and3cylinders said: My pyramid rear hugger extension also helps keep things clean particularly muck from getting thrown at the shock There are some gaps in the o e m rear hugger that need to be filled with foam or caulk that Otherwise allow muck to pass thru them and get on the shock Thanks for that. Because you have to fill in gaps I ordered a different one for the rear. I’ll order the pyramid one for the front fender though. Link to comment Share on other sites More sharing options...
Supporting Member texscottyd Posted June 23, 2023 Supporting Member Share Posted June 23, 2023 @Headgas - I picture the radiator guard and fender extender as serving two separate purposes, that just happen to overlap a bit. For protection, a good radiator guard is the way to go. The only noticeable ding I gave in mine is way up high on the radiator guard… obviously a rock or other debris that came directly in above the front fender. A mudguard isn’t going to do anything to lessen that risk. The fender extender should help keep the front of the motor & exhaust clean, but I wouldn’t count on it for protection beyond basic splash control. 1 Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted June 23, 2023 Premium Member Share Posted June 23, 2023 6 hours ago, Headgas said: Thanks for that. Because you have to fill in gaps I ordered a different one for the rear. I’ll order the pyramid one for the front fender though. I'll bet you a six pack of my favorite brew that the gaps will still be there with a full hugger replacement. As an injection moulding thermoplastic manufacturing engineer I know The attachment points for the hugger make it difficult to not leave gaps. The rearward coverage of all the full hugger replacements do not extend more than a 1/2 inch further back than my Pyramid. Hugger extension. The stock hugger is very durable so attaching an extension to It was a piece of cake and looks cool too with the c f. Link to comment Share on other sites More sharing options...
Denideul Posted June 25, 2023 Share Posted June 25, 2023 Anybody has tried this model from Pyramid ? it seems to be more enveloping. Link to comment Share on other sites More sharing options...
Ride365 Posted June 25, 2023 Share Posted June 25, 2023 1 hour ago, Denideul said: Anybody has tried this model from Pyramid ? it seems to be more enveloping. I have the extender, but think I will go this route over that......thanks for sharing. Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted June 25, 2023 Premium Member Share Posted June 25, 2023 I found with the extender comparing it to full hugger replacements that they're only about a 1/2" shorter Link to comment Share on other sites More sharing options...
