rockwoodroo Posted August 27, 2015 Share Posted August 27, 2015 I mentioned to the dealer that I was noticing a 7% difference between the speedo and the GPS (Speedo ahead of GPS reported sped). He mentioned they have made Yamaha aware of this without any results. As well he mentioned this would not affect the odometer. I would be ok with 1-2% but 7%? Link to comment Share on other sites More sharing options...
Premium Member clint Posted August 27, 2015 Premium Member Share Posted August 27, 2015 I mentioned to the dealer that I was noticing a 7% difference between the speedo and the GPS (Speedo ahead of GPS reported sped). He mentioned they have made Yamaha aware of this without any results. As well he mentioned this would not affect the odometer. I would be ok with 1-2% but 7%? I'm consistently experiencing 1.04%, seeing 60 on the speedometer and 58 on the GPS. Piedmont of NC '15 FJ-09 '94 GTS-1000 Link to comment Share on other sites More sharing options...
skipperT Posted August 27, 2015 Share Posted August 27, 2015 Known issue for all motorcycles. The FJ is more accurate then most. If you are concerned, order and install something called a "speedo healer". They work fairly well, and make it more accurate especially after a gearing change. -Skip Link to comment Share on other sites More sharing options...
Premium Member alejandro Posted August 27, 2015 Premium Member Share Posted August 27, 2015 I poked around a little, and here's some of what I found: - In Europe, speedos are not allowed to read below actual speed, but they may read high by up to 10% plus 4 kph! - In the US, some amount of variation is allowed. - In the US, if the speedo reads low and someone gets a ticket, they would have an easier time sueing the manuf! - Different tires, even with the same nominal size, might have a slightly larger diameter. I'm not sure why all of this doesn't apply equally with cars--car speedos seem to be much more accurate on the whole. Link to comment Share on other sites More sharing options...
