papac2000 Posted May 9, 2015 Share Posted May 9, 2015 Since my dealer did NOT do it. Wish me luck. 2015 Matte Grey Modded stock exhaust, modded stock screen, modded stock seat, OEM heated grips, LED indicators, FlashTuned ECU, ZX10R shock Link to comment Share on other sites More sharing options...
Premium Member clint Posted May 9, 2015 Premium Member Share Posted May 9, 2015 Since my dealer did NOT do it. Wish me luck.Please document with pictures and then come to my house to perform. 8-) I'll tap the keg for you. Piedmont of NC '15 FJ-09 '94 GTS-1000 Link to comment Share on other sites More sharing options...
papac2000 Posted May 9, 2015 Author Share Posted May 9, 2015 Took about 2hrs for me to do. Took a few pics. May not have much for documentation, but 1 tip from a friend that was helpful. Made a minor airbox lid mod while I was in there too. Pics to follow 2015 Matte Grey Modded stock exhaust, modded stock screen, modded stock seat, OEM heated grips, LED indicators, FlashTuned ECU, ZX10R shock Link to comment Share on other sites More sharing options...
papac2000 Posted May 9, 2015 Author Share Posted May 9, 2015 Turning the tank backwards with everything connected was a good idea a friend of mine suggested. The piece of foam is to protect the bike, although I'm sure towels would work. 2015 Matte Grey Modded stock exhaust, modded stock screen, modded stock seat, OEM heated grips, LED indicators, FlashTuned ECU, ZX10R shock Link to comment Share on other sites More sharing options...
papac2000 Posted May 9, 2015 Author Share Posted May 9, 2015 ECU removed and hanging. Note the air inlet on the top of the airbox at the front. More on that in a bit. 2015 Matte Grey Modded stock exhaust, modded stock screen, modded stock seat, OEM heated grips, LED indicators, FlashTuned ECU, ZX10R shock Link to comment Share on other sites More sharing options...
papac2000 Posted May 9, 2015 Author Share Posted May 9, 2015 Airbox off, vacuum lines connected. The bypass screw for cyl #1 (far left in pic), is painted white. It is the reference, and the other two are to match its readings. 2015 Matte Grey Modded stock exhaust, modded stock screen, modded stock seat, OEM heated grips, LED indicators, FlashTuned ECU, ZX10R shock Link to comment Share on other sites More sharing options...
papac2000 Posted May 9, 2015 Author Share Posted May 9, 2015 Vacuum gauge rack. Borrowed, not mine...lol. 2015 Matte Grey Modded stock exhaust, modded stock screen, modded stock seat, OEM heated grips, LED indicators, FlashTuned ECU, ZX10R shock Link to comment Share on other sites More sharing options...
papac2000 Posted May 9, 2015 Author Share Posted May 9, 2015 Ever the tinkerer, I noticed the airbox inlet tube was quite close to the bottom of the airbox. It used to be straight across, I cut 1in lower on the side nearest the air filter and angled it back to the uncut side which is right next the front of the box. I think this could help the air turn instead of slamming into the floor. Only the dyno will tell I guess. 2015 Matte Grey Modded stock exhaust, modded stock screen, modded stock seat, OEM heated grips, LED indicators, FlashTuned ECU, ZX10R shock Link to comment Share on other sites More sharing options...
Premium Member clint Posted May 9, 2015 Premium Member Share Posted May 9, 2015 Looks like cylinder #4 vacuum is way off!! Piedmont of NC '15 FJ-09 '94 GTS-1000 Link to comment Share on other sites More sharing options...
fzkenm Posted May 9, 2015 Share Posted May 9, 2015 Ever the tinkerer, I noticed the airbox inlet tube was quite close to the bottom of the airbox. It used to be straight across, I cut 1in lower on the side nearest the air filter and angled it back to the uncut side which is right next the front of the box. I think this could help the air turn instead of slamming into the floor. Only the dyno will tell I guess. Very interesting. Your theory certainly sounds logical. Wonder why Yamaha wouldn't have done that if it is an improvement? Look forward to hearing what your results on the dyno show. If it's an improvement, that would be something anyone could easily do. Link to comment Share on other sites More sharing options...
quicksilver Posted May 9, 2015 Share Posted May 9, 2015 Did yours require any adjustment and what mileage? I just did my first at 2100 mi and no adjustment was required. Link to comment Share on other sites More sharing options...
Guest lawrenceofsuburbia Posted May 9, 2015 Share Posted May 9, 2015 ECU removed and hanging. Note the air inlet on the top of the airbox at the front. More on that in a bit.Whenever I see a pic like this - a bike with all it innards hanging out - I cannot help but marvel at [em](a)[/em] the complexities of these modern-day bikes and given that [em](b)[/em] their (usual) utter reliability![em]Gobsmacked![/em]L of S Link to comment Share on other sites More sharing options...
papac2000 Posted May 10, 2015 Author Share Posted May 10, 2015 Did yours require any adjustment and what mileage? I just did my first at 2100 mi and no adjustment was required. 1800kms. Was pretty close, was nitpicking really to make any adjustments, but since I had gone that far, I made small tweaks. I also noted however that just off idle there was a bit greater disparity than at closed throttle, so I took that into consideration as well. 2015 Matte Grey Modded stock exhaust, modded stock screen, modded stock seat, OEM heated grips, LED indicators, FlashTuned ECU, ZX10R shock Link to comment Share on other sites More sharing options...
gregman Posted May 11, 2015 Share Posted May 11, 2015 Ever the tinkerer, I noticed the airbox inlet tube was quite close to the bottom of the airbox. It used to be straight across, I cut 1in lower on the side nearest the air filter and angled it back to the uncut side which is right next the front of the box. I think this could help the air turn instead of slamming into the floor. Only the dyno will tell I guess. I guarantee the big snorkel is for noise abatement. Twenty bucks says cutting that thing an inch or less from the lid (and subsequent dyno reflash) will net 5-10 HP by itself (and will make the intake sound amazing). '15 FJ-09 Red is the fastest color! Prototype Parabellum screens Shogun sliders SC seats Radiator screen Link to comment Share on other sites More sharing options...
cricket1 Posted May 11, 2015 Share Posted May 11, 2015 Possibly cutting that intake will net the improvement gregman noted. Or maybe not... at all. See Yamaha has a bunch of engineers whose job is it to get the most out of something, within the given parameters. Some times those parameters include noise and EPA regs that we typically care little about, so mucking around with stuff can yield real improvements. Other times bikes get all hacked up, and actually lose power. Link to comment Share on other sites More sharing options...
