Premium Member joeszup Posted March 7, 2017 Premium Member Share Posted March 7, 2017 Heh, I started my 4K maintenance yesterday. Not in a big rush, so I'm using the downtime to also clean the bike top to bottom as I disassemble the biker upper. Everything is apart and cleaned, probably get the throttle body and spark plug gaps done this week sometime. @xlxr flagged something you might also want to check while you have access... check here. Thanks for the heads up. I'll check it out. Link to comment Share on other sites More sharing options...
peteinpa Posted February 25, 2021 Share Posted February 25, 2021 Wanted to put this here since I had exactly this problem today. I turned all my screws in and my middle TB wasn't my primary. #1 TB became my primary. I used a 35 year old mercury Carb. Styx, still works. If anything it's too sensitive. Just had the ECU flashed. I must have gone through 10 cycles of the cooling fan even at 40F outside temp. Link to comment Share on other sites More sharing options...
