kimofj Posted February 5, 2017 Share Posted February 5, 2017 Today I noticed that my FJ won't start in gear with the clutch pulled in and side stand up. I had to shift it to Neutral to start it. I did put on heated grips but can't figure how that would make the clutch safety switch not work. I meter checked the switch and it's switching. The wires going to the switch seem to be dead... are they fused if so where is the fuse? thanks Jim in Ojai ca Link to comment Share on other sites More sharing options...
JJM Posted February 5, 2017 Share Posted February 5, 2017 Do these bikes have a clutch safety switch? Maybe your kickstand switch is going bad? Link to comment Share on other sites More sharing options...
Premium Member wessie Posted February 5, 2017 Premium Member Share Posted February 5, 2017 you need to trace the wire back - if there is no voltage on the switch then you probably have a loose connector somewhere. Have you had any modifications? If so, check for a pinched wire as this may also cause a fault. If you have undone any connectors check the pins - easy to bend one when reinserting the plug. This signature is left blank as the poster writes enough pretentious bollocks as it is. Link to comment Share on other sites More sharing options...
bruceintucson Posted February 6, 2017 Share Posted February 6, 2017 Today I noticed that my FJ won't start in gear with the clutch pulled in and side stand up. I had to shift it to Neutral to start it. I did put on heated grips but can't figure how that would make the clutch safety switch not work. I meter checked the switch and it's switching. The wires going to the switch seem to be dead... are they fused if so where is the fuse? thanks Jim in Ojai caThere's a 2 wire switch at the clutch lever, you probably didn't reconnect it (correctly). Link to comment Share on other sites More sharing options...
Premium Member bttrthnwrk Posted February 6, 2017 Premium Member Share Posted February 6, 2017 When I first got my bike, it wouldn't start in gear, either, even with the clutch pulled in. After getting annoyed enough with it, I finally checked the clutch lever switch plug. It was loose and pulled right out after gently tugging on the cable. I pushed it in pretty hard using the tip of a needle nose plier and tried tugging the cable again. It pulled out again. The next time, I pushed it it what felt like WAY too hard, and the plug caught and stayed in afterward when I tugged on it. Don't follow. Don't lead. Don't join. Link to comment Share on other sites More sharing options...
kimofj Posted February 7, 2017 Author Share Posted February 7, 2017 I reconnected the two prong plug pushing it in really hard and bingo it starts in gear with the clutch in. Huh odd. Jim in Ojai Link to comment Share on other sites More sharing options...
