Need case cover torque specs for 2016 FJ-09
corkey
  • 2 weeks later...
I need torque specs for fork clamps screws, front axle and brake caliper bolts.
Should be same on all years, mine is 2018 GT.
Honda CB600F Hornet 2008; KTM LC4 640 SM Prestige 2007; Kawasaki Z1000 2007; Honda CB1000R 2010; BMW R1200GS 2010; Yamaha Tracer 900GT 2018; Yamaha TDM900 2002; Kawasaki KLX230 2020; KTM 690 Enduro R 2022: Bold = current
Ok, now I want to know what you have been up to 🤔
Upper fork clamp 26Nm (19 ft/lb)
Lower fork clamps 23 Nm (17 ft/lb)
Front axle 65 Nm (47 ft/lb)
Pinch bolt 23 Nm (17 ft/lb)
Brake caliper bolts 35 Nm (25 ft/lb)
I'm just cleaning the bike :)
öhlins FKS504 cartridges arrived a month earlier...
Thank you very much Sir.
Hopefully also rear YA537 shock will arrive today. I have yet to decide about fitting stabilizer.
Definitely get your suspension sorted out first.  Your shock should have a ride height adjustment, raising the rear a few millimeters along with lowering the front (raising the forks in the clamps) really made a noticeable difference in stability and handling on my bike.
Once it is setup correctly, chances are you wont need a steering stabilizer.  That's $450 you could otherwise spend on tires or gas and beer on a summer road trip! (beer after the ride of course). 👍
I intend to set it up according to Öhlins recommended settings.
Öhlins manuals say front sag 30-40mm, rear 25-35mm with rider. So I'll do that.
With stock suspension I had front at 42mm and rear at 38mm and front preload was all the way in to the max because original springs aren't correct for this bike.
I liked this article for setting up your forks @krucymucy. I thought it was a more pragmatic approach than just setting some figures from a manufacturer.
http://www.gostar-racing.com/club/motorcycle_suspension_set-up.htm#Front Preload
