Premium Member fr8dog Posted December 15, 2018 Premium Member Share Posted December 15, 2018 Trying to tighten the lower shock bolt. After tightening as much as I can, there is still a little wiggle. Maybe a mm or so. Any sugestions? Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted December 15, 2018 Supporting Member Share Posted December 15, 2018 If you are talking about up and down movement of the swingarm, that is normal. All of my bikes, street or dirt, have done that, even after brand new bearings and seals. ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Premium Member fr8dog Posted December 15, 2018 Author Premium Member Share Posted December 15, 2018 21 minutes ago, betoney said: If you are talking about up and down movement of the swingarm, that is normal. All of my bikes, street or dirt, have done that, even after brand new bearings and seals. No - side to side on the shock itself. On the bottom of the shock where it bolts to the swingarm. The bolt and nut are somewhat lower and not a straight shot for a ratchet. Can't get enough pressure with wrenches. Link to comment Share on other sites More sharing options...
Supporting Member piotrek Posted December 15, 2018 Supporting Member Share Posted December 15, 2018 There is movement there because the bolt actually pinches the inner bearing race, which is slightly longer than the width of the arm. Have a look at the photo. All three of these float side-to-side slightly. You will need an offset tool into there to torque down the one you mention. Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted December 15, 2018 Supporting Member Share Posted December 15, 2018 10 minutes ago, fr8dog said: No - side to side on the shock itself. On the bottom of the shock where it bolts to the swingarm. The bolt and nut are somewhat lower and not a straight shot for a ratchet. Can't get enough pressure with wrenches. When I originally replaced my shock, I ended up buying some Ratcheting-Flex Wrenches to gain proper access. When I recently removed my shock to have it serviced, I found it was much easier to remove the swingarm to gain access, VERY simple process, it just takes a few minutes. With the swingarm removed you have access to fully tighten everything properly. Not to mention that greasing your linkage and swingarm bearings should be annual maintenance. ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Premium Member fr8dog Posted December 15, 2018 Author Premium Member Share Posted December 15, 2018 Thanks fellas. I guess I'm good then. Time to test ride. Link to comment Share on other sites More sharing options...
Premium Member fr8dog Posted December 17, 2018 Author Premium Member Share Posted December 17, 2018 On 12/15/2018 at 11:27 AM, piotrek said: There is movement there because the bolt actually pinches the inner bearing race, which is slightly longer than the width of the arm. Have a look at the photo. All three of these float side-to-side slightly. You will need an offset tool into there to torque down the one you mention. Are those races pressed in or do they slide out easily? Link to comment Share on other sites More sharing options...
Supporting Member piotrek Posted December 17, 2018 Supporting Member Share Posted December 17, 2018 4 minutes ago, fr8dog said: Are those races pressed in or do they slide out easily? They slide out easily. There is a seal on each side of the bearing. Link to comment Share on other sites More sharing options...
BBB Posted December 17, 2018 Share Posted December 17, 2018 I couldn’t get the top (widest) tube out of my swing arm when I tried so I had to settle for lubing what I could see. The other two came out easily. Do you have to use anything to get the top one out? Red 2015 Tracer, UK spec (well, it was until I started messing with it...) Link to comment Share on other sites More sharing options...
Supporting Member piotrek Posted December 17, 2018 Supporting Member Share Posted December 17, 2018 1 hour ago, BBB said: ....Do you have to use anything to get the top one out? No... should come out like the others. Link to comment Share on other sites More sharing options...
