wordsmith Posted March 26, 2019 Share Posted March 26, 2019 Could someone kindly identify the tech spec of the bolts highlighted in the pic below? They are the four hex-heads behind the windscreen that secure the screen mounting-plate onto the raising/ lowering mechanism behind. I'm hopeless at identifying what sort of threads are on any given screws or bolts, as a result of which I have scores of the wrong ones bought on guesswork! Thanks in anticipation! Riding a fully-farkled 2019 MT-09 Tracer 900 GT from my bayside home in South East Queensland, Australia. Link to comment Share on other sites More sharing options...
Buggy Nate Posted March 26, 2019 Share Posted March 26, 2019 Hi mate, they are domed Allen head bolts. Hex heads are the reverse if you will. For example they use a spanner or a socket. I believe from memory they are 6mm x 1.0 x 15mm long. The 6mm refers to the bolts thread diameter and the 1.0mm refers to the spacing between threads. For length you measure from the end of the thread to under the bolt head. Or in the case of countersunk bolts/screws up to the countersunk head. Link to comment Share on other sites More sharing options...
tinkerfreak Posted March 26, 2019 Share Posted March 26, 2019 This is when a thread pitch gauge and a bolt/screw size gauge come in real handy and can usually be picked up fairly cheap. Cheers Link to comment Share on other sites More sharing options...
wordsmith Posted March 26, 2019 Author Share Posted March 26, 2019 Thanks Nate: I always thought that hex head and Allen head were one and the same thing! Off to Bunnings tomorrow! How's it going down there in sunny Goulburn? My #3 grandson is courting (to use an olde-fashioned term) a gal in the Academy there, graduating in May, I bleeve. Riding a fully-farkled 2019 MT-09 Tracer 900 GT from my bayside home in South East Queensland, Australia. Link to comment Share on other sites More sharing options...
Buggy Nate Posted March 27, 2019 Share Posted March 27, 2019 Won’t get decent bolts from Bunnings mate. Best to find a decent nut and bolt place locally. That way you get to just throw the on the counter and let them match them up for you! 😜 Out of Goulburn now thankfully. It has been good, really busy though! Link to comment Share on other sites More sharing options...
