v1nn1e Posted February 24, 2020 Share Posted February 24, 2020 (edited) My bike had a couple of years living out on the kerbside and it shows with general corrosion here and there. This includes the lower engine bolts, including the sump ones and I'm wondering about replacing them all, just for a bit of cosmetic bling! If I were to go ahead, would the threads of the new bolts need a drop of something on them prior to insertion? Either: Thread lock? Copper grease? Anyone know if the factory put something on these bolts before assembly? Thanks Edited February 24, 2020 by v1nn1e replaced hear with here Link to comment Share on other sites More sharing options...
BBB Posted February 24, 2020 Share Posted February 24, 2020 The general rule with bolts is to insert them dry otherwise you alter the torque setting required. However, IMHO that only matters when you’re using high torque values or critical bolts. The sump bolts do not use loctite. To keep the new fasteners in better condition you could replace them with marine grade stainless and give them a quick spray of ACF 50 once they’re tightened. 1 Red 2015 Tracer, UK spec (well, it was until I started messing with it...) Link to comment Share on other sites More sharing options...
Willie17FJ-09 Posted February 24, 2020 Share Posted February 24, 2020 I have used corrosion X spray. It kills and prevents corrosion. It’s great on aluminum , kind of expensive, but worth it. Probably won’t remove rust from steel but will prevent rust https://www.amazon.com/CorrosionX-Aviation-oz-aerosol-80102/dp/B000FOLXFW/ref=mp_s_a_1_3?keywords=corrosion+x+aerosol&qid=1582576009&sr=8-3 Link to comment Share on other sites More sharing options...
v1nn1e Posted March 4, 2020 Author Share Posted March 4, 2020 Thanks for the info. Never heard of CorrosionX before. Is this an ACF50 competitor...? Link to comment Share on other sites More sharing options...
BBB Posted March 4, 2020 Share Posted March 4, 2020 @v1nn1e, I’ve just started using XCP on my oil cooler, based on this review and also in Motorcycle News. Its similar in action to ACF 50 but leaves a thicker film. Tested: XCP Rust Blocker corrosion protectant review BikeSocial’s seven month, in-depth test of rust proofers for your motorcycle Red 2015 Tracer, UK spec (well, it was until I started messing with it...) Link to comment Share on other sites More sharing options...
