Skidood Posted December 12, 2020 Share Posted December 12, 2020 (edited) Just set up my spring preloads as per "recommended methods", and thought I would share what I discovered as "optimal" settings for front and rear spring preload. Maybe one day someone will find this a bit helpful. Bike is brand new, zero miles. I weigh 195 lbs. I measured wheel travel (compression travel) while sitting down on bike, and compared to factory wheel travel specs. I targeted 30% compression linear travel (suspension compresses 30% of full travel when rider weight is added.) (I started with baseline measurements with wheels off the ground) Rear: 5 full turns in (clockwise) from fully backed off (full CCW) (full span of adjustment is ~ 13 turns) (the sweet black adjustor knob) Forks: 9 full turns in " " " " " " " " (full span of adjustment is ~ 16 turns) Edited December 12, 2020 by Skidood 1 Link to comment Share on other sites More sharing options...
Ride365 Posted December 12, 2020 Share Posted December 12, 2020 Not nearly enough for the rear shock and I am of similar weight, and what about your other settings for the forks? Link to comment Share on other sites More sharing options...
Skidood Posted December 12, 2020 Author Share Posted December 12, 2020 Well the settings are inherently just preliminary until I get her out. I will want the ride to be a bit on the soft side due to back problems. The damping settings I set around 60% for now. They wont get dialed in for another 4 or 5 looong months. Link to comment Share on other sites More sharing options...
PhotoAl Posted December 13, 2020 Share Posted December 13, 2020 Good info, is that 195 pounds with gear? I'm 175 plus gear and don't think I have that much on the front but about the same on the rear. I'm pretty happy with where I am on setting now. When I load up and go touring will stiffen the back up a fair amount and the front somewhat. Bought my bike in South Dakota while on a trip (trip turned adventure), literally rode it out of the dealer with stock settings, fully loaded, 110 miles back to where I was staying. Put 600 miles on it, had it serviced then headed home. On the 1,400 mile trip home I realized hadn't adjusted preload so set them to the full settings from the manual. When I got home and unloaded the bike was so stiff I couldn't get the rear to bounce at all! Since I've softened it up and am a little harder than the "stock" settings with a bit more compression and rebound - 1 or 2 clicks more. It does OK for me and handles very nicely. Read too many postings and it has taken me a while to get confidence in the front but it sticks very nicely. LOL Ive tried to bounce the front in my garage and usually don't have much success. Link to comment Share on other sites More sharing options...
