OSG55 Posted April 15, 2021 Share Posted April 15, 2021 I have a seat/tail bag that carries all of my daily ride stuff. It is transferred between multiple bikes so I don't have to repack everything each time I ride a different bike. My 2015 FJ-09 required removal of the passenger grab rails to allow the bag to be mounted securely. Only issue is that 2 large holes are left on top of the tail section where the rear of the grab rails are attached. Unsightly and not exactly weather resistant. Solution: 1-1/2" diameter steel washer (painted matte black) installed over 1-1/2" x 1/8" thick soft rubber washer, secured with the stock grab rail bolt. See attached photos. (NOTE: The aluminum mounting boss for the grab rail sits a little proud of the plastic tail section cover surface, requiring a soft rubber washer at least 1/8" thick to conform to the boss and seal to the tail section cover. A hard plastic washer will not effectively seal the opening. Soft rubber washer with a 3/8" center hole effectively seals the bolt shaft.) While it may not be the most visually pleasing solution (more "industrial design/steam punk" than sleek...) it seals the openings, is fairly unobtrusive, rattle-free, and allows for quick re-installation of the grab rails. Link to comment Share on other sites More sharing options...
BBB Posted April 15, 2021 Share Posted April 15, 2021 That’s a good solution. I’d be tempted to fit cargo tie downs on that bolt, to help lash anything onto the back seat as you’ve lost the rails. It could be a simple loop or something like this (but the right size of course). Red 2015 Tracer, UK spec (well, it was until I started messing with it...) Link to comment Share on other sites More sharing options...
Supporting Member dazzler24 Posted April 15, 2021 Supporting Member Share Posted April 15, 2021 Or something like this perhaps? 1 Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted April 15, 2021 Supporting Member Share Posted April 15, 2021 5 hours ago, dazzler24 said: Or something like this perhaps? I use something very similar for my cargo net. I use them on the side case attachment bolts as well. 2X Motorcycle Tie-Down Tie Down Strap Rings For DIRT BIKE Replace 3920-0341 US Item do not fit your motorcycle perfect. We have professional team to care... ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
