thohod Posted July 31, 2015 Share Posted July 31, 2015 Is it possible to get a close up picture of where the rear carrier mounts to the side of the bike? I have the Shad SH36 side bags and for those to be installed I have to remove the Yamaha side bag hooks. I just want to be sure the rear carrier can still be added after I remove the yamaha side bag hooks. Link to comment Share on other sites More sharing options...
rockwoodroo Posted September 11, 2015 Share Posted September 11, 2015 i mounted mine the same way. i did get it on with the hardware that came with it but it was to far back on the rack. they should provide longer bolts but it isnt a big deal. i got tired of waiting for the oem luggage so i ordered the sh42. they were out of them so they offered me an sh45 at no extra charge. im happy with it and very happy with the customer service. good people. Hi, Could you post or PM a picture on how your install ended up by using the original Shad hardware? Just to get a sense on how far back it is and if it is still usbale with the backrest for a passenger that far back. Thanks. Link to comment Share on other sites More sharing options...
cole2757 Posted September 12, 2015 Share Posted September 12, 2015 it was only an inch or so back from where it is in the pictures. i dont know that it would make much difference to a passenger. it looked funny though cause the shad mount doesnt fit snug to the grab rails anyway. Link to comment Share on other sites More sharing options...
praztek Posted December 30, 2015 Share Posted December 30, 2015 Hello, great write up ,would this also work with the shad48 ? Thanks Link to comment Share on other sites More sharing options...
praztek Posted January 10, 2016 Share Posted January 10, 2016 Hello, great write up ,would this also work with the shad48 ? Thanks I got it to work last evening had to modify the front and rear holes now waiting for the backrest to come in. Link to comment Share on other sites More sharing options...
Premium Member stealth09 Posted January 16, 2016 Premium Member Share Posted January 16, 2016 I installed the Shad SH45 on my Yamaha rack today. As with the OP I did not use the Yamaha plastic top rather mounted the Shad mounting plate directly to the rack frame. I was also able to mount it using the supplied hardware. The front is secured in the same manner as the OP. I removed the plastic divider from the slotted holes and used the supplied allen bolts in the threaded bosses built into the rack. With the front secure, I used a small drill bit to come up through the hole in the rear threaded bosses from underneath the rack. I used this to make holes marking the locations in the mounting plate. These holes were then enlarged from the top to allow the supplied bolts to secure in the threaded bosses. I used the supplied spacers between the threaded boss on the rack and the mounting plate. Hope that's clear as mud. I'm very happy with it. It looks OEM IMHO. Thanks for sharing your ideas. Link to comment Share on other sites More sharing options...
Premium Member stealth09 Posted January 16, 2016 Premium Member Share Posted January 16, 2016 Here is how I mounted the Shad baseplate to the Yamaha rack, without the rack cover, using the supplied hardware. The front and rear fasteners. [attachment id=496" thumbnail="1] Front: allen bolt from the rack kit (RK ) with bracket from mounting plate (MP). This screws into the front threaded boss of the rack. [attachment id=497" thumbnail="1] Rear: Philips head screw from MP with flange bushing from RK going through hole drilled in MP (as described in last post) then red spacer from MP and screws into rear threaded boss. [attachment id=498" thumbnail="1] Mounting plate installed. [attachment id=499" thumbnail="1] Link to comment Share on other sites More sharing options...
Premium Member clint Posted January 16, 2016 Premium Member Share Posted January 16, 2016 Nicely done! Looks OEM! Piedmont of NC '15 FJ-09 '94 GTS-1000 Link to comment Share on other sites More sharing options...
Premium Member stealth09 Posted January 17, 2016 Premium Member Share Posted January 17, 2016 Top case installed. [attachment id=501" thumbnail="1] [attachment id=502" thumbnail="1] I weighed the luggage. Yamaha side cases - 11.2 lbs ea. Shad top case - 7.4 lbs So in less than a minute I can shed 30 lbs. [attachment id=508" thumbnail="1] And have a clean FJ again. [attachment id=507" thumbnail="1] Link to comment Share on other sites More sharing options...
avro Posted January 17, 2016 Share Posted January 17, 2016 Really looks good! -- I've been beating around with whether to go with the Yamie city side cases or not due to cost but IMOP they look the best and really suit the bike , they are on the smaller size but that helps the look and as you've taken care of that with Top case and helment storage . Is the Top rack Yamaha or SW-Motech? as I'm looking to go with a similar set-up... Link to comment Share on other sites More sharing options...
Premium Member stealth09 Posted January 18, 2016 Premium Member Share Posted January 18, 2016 Really looks good! -- I've been beating around with whether to go with the Yamie city side cases or not due to cost but IMOP they look the best and really suit the bike , they are on the smaller size but that helps the look and as you've taken care of that with Top case and helment storage . Is the Top rack Yamaha or SW-Motech? as I'm looking to go with a similar set-up... Thanks. The rack is OEM Yamaha. Instead of installing the yammie plastic cover I put the Shad mounting plate on the racks metal frame. Link to comment Share on other sites More sharing options...
