peteinpa Posted December 29, 2022 Author Share Posted December 29, 2022 Yeah it's not a good design at it's best. Sargents plastic pan is thinner/weaker also, making it worse. Pretty sure I'm done with Yamaha come spring. 92 Honda Nighthawk for me. Long seat so you're not locked in one spot. Seat supported on the frame rails, no stupid torque values, No valves to adjust ever, it's going on and on. Shouldn't have left Honda. Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted December 30, 2022 Premium Member Share Posted December 30, 2022 Revised rear saddle bumper resupport; removed added rubber blocks at rear latch. Seems more stable side-to-side now. 0.32" (1.28 mm) thick prefinished steel sheet metal cut to size supported on high durometer rubber blocks as needed to match height of OEM bearing points. 1 Link to comment Share on other sites More sharing options...
